magni
Hey guys, i'm prepared to spend ABIT of money on getting down the G's. So what can i do that will make a good difference?
I'll be getting those flyweight tubes and what is a reasonably light freeridy type tyre?
Cheers fellers
By the way does anyone know how much my pedals weigh? (Dice comps)
(08 Mongoose Khyber Elite)
# Color(s): Blue/White fade
# Size(s): S, M, L
# Frame: FreeDrive AM/FR 6.5" (165 mm) travel
# Fork: Marzocchi 55 TST2, 160 mm travel, air spring, rebound, compression, preload adjust and 20 mm tool free axle
# Rear Shock: Marzocchi Roco Air R Piggy Back, air spring with rebound adjust and piggy back reservoir. (8.5x2.5")
# Crankset: FSA Moto X, 24/36T/bash guard w/ pedal insert
# Bottom Bracket: FSA MegaExo external bearing
# Pedals: Dice
# Front Derailleur: Shimano Deore
# Rear Derailleur: SRAM X.7 mid cage
# Shifters: SRAM X.7 Impulse trigger 9 speed
# Freewheel: SRAM PG-950 11-34T 9 speed
# Chain: KMC Z-9200 silver/black
# Rims: WTB Dual Duty FR, 32°
# Tires: Kenda 26x2.35 Nevegal DTC, folding bead
# Front Hub: Mongoose 20 mm thru axle Alloy Disc 32°
# Rear Hub: Shimano FH-M530 disc, 8/9 speed cassette, 32°
# Spokes: Stainless steel
# Nipples: brass UCP
# Front Brake: Hayes Stroker Trail hydraulic disc, 180 mm rotor
# Rear Brake: Hayes Stroker Trail hydraulic disc, 160 mm rotor
# Brake Levers: Hayes Stroker Trail, tool free reach adjust
# Handlebar: Funn 6061AL ,30 mm rise, 31.8 mm
# Stem: Funn Rippa 65 mm, 10°
# Grips: Jet black
# Headset: FSA Orbit E 1.5" to 1-1/8" conversion, internal bearing
# Saddle: WTB Pure V Race w/ cromo rails
# Seat Post: M-logo 2014 alloy w/ double bolt integral head 300/350mm length 31.6mm
# Seat Clamp: Alloy Q/R
Cheers fellers
# Size(s): S, M, L
# Pedals: Dice
# Grips: Jet black
