And my creation is finally complete!!!
Frame - Liteville 301 mk14 XXL 160mm 29er
Rear shock - RS Deluxe -> DVO Topaz 2 -> Fox DPX2
Front shock/fork - RS Lyrik 180mm, SD Components lsc/hsc charger upgrade, C1 airspring.
Handlebars - Spank Spike Vibrocore 780mm
Stem - Thomson X4 40mm
Headset - Syntace -1.5°
Grips - Syntace
Saddle - Selle SMP Hybrid
Seatpost - PNW Bachelor 34.9 150mm
Front brake - Formula Cura 4
Rear brake - Formula Cura 4
Cranks - RF Turbine 175mm boost 32/22
Chainguide - Syntace
Chain - KMC
Pedals - Time MX4
Front derailleur - Shimano XT
Rear derailleur - Shimano XT
Front shifter - Shimano XTR
Rear shifter - Shimano XTR
Cassette - Shimano XT 11-40
Front hub - I9 Torch boost
Rear hub - I9 Torch boost
Front rim - Nextie asymmetric enduro
Rear rim - Nextie asymmetric enduro
Spokes - Sapim race
Nipples - Sapim polyax
Tyres - Onza Ibex/Maxxis Aggressor
Tubelesss - Rimpact inserts
Total weight - ~14kgs
It's not quite completed yet but I can confidently say two things about it.
Given that I've gone up a size and I'm running the -1.5° headset, its definitely had a bit of the Grim Donut treatment. I'm also running a 40mm stem to compensate for the increased reach compared to my mk13 XL which has a 70mm stem and narrower 760mm bars.
It will be interesting to compare it to the Pole which has slightly less travel but is a heavier, slacker and longer bike.
I'm also looking forward to trying the Cura 4s and comparing to the Frankenbrake 6 pots on the Pole.
Grips - Syntace
Chain - KMC
Pedals - Time MX4
Spokes - Sapim race
- Its even more over-engineered then the mk13.
- The internal cable routing is neat but a royal pain in the ass. This has added half a day to the build, even with an internal routing tool.
