Warp
Hi, All!!
I was doing a race last Sunday where the rear end of the bike rattled like crazy, the drivetrain would refuse to shift from 3rd to 4th cog either up or down and it was a nightmare but it was holding up.
After the race, I noticed that the lockring and cassette were loose on the freehub.
I checked today and there is no major damage, the lockring and freehub threads appear to be fine, the smaller cogs did chew a little bit on the freehub but no filing or fighting was necessary to remove the cogs or put them back in.
Now, upon reassembly, I noticed that the two 3-cog carriers fit loose on the hub. The splines look OK in there, but you can rock the cogs fore-aft when the lockring is loose. WTF?
That takes me to the real issue. I can't seem to tighten the lockring as much as on other hubs I have had. I would tighten and then if I keep tightening, it would come loose again. Threads look ok, though. Crazy. I would expect the threads on the lockring or freehub to be damaged but it doesn't look that is the case.
This cassette was working like a charm on my Hadley... I need to ride it again to discard that I left the lockring too loose but I am wondering if I am missing something.
What am I missing???
It just seems too weird that the lockring would tighten up and then come loose if you keep tightening it without damaging the threads either on the lockring or freehub?
Anybody has had these issues with Shimano XT CS-M771 cassettes on Hope Pro II EVO hubs?
Again, the cassette did fit tight on the Hadley.
What is a better lockring replacement? Something with deeper threads and/or steel?
Thanks!
Thanks!
