By the way OP, that isn't "easy gear front and rear". Its actually "small small".
The easy gear front and rear is small front ring and big rear cog.
You shouldn't ever use small small because it has a terrible chain line, and more importantly, the chain tension in that combination is extremely high and it will wear your drivetrain really quickly. That's why its sometimes okay to have a loose chain in that combo, because you should never shift into it.
The bit in bold is completely wrong. There is fuck-all chain tension in small-small, because the rear derailleur is close to its most relaxed state, so isn't doing all that much to apply tension to the chain. The gears can tend to run like shit in that combination due to chain slap from
insufficient tension. Any extra wear is due to the relatively few points of chain engagement, therefore each point bearing greater proportional load.
Excessive chain tension and the problems that go with it are found at the other extreme, big-big. The derailleur is pulled hard against its spring, so exerts greater force to pull back at the chain. The greater radii of the front & rear sprockets mean the effective length between the closest contact points is reduced, thereby exacerbating the extermity of the chain angle. This high oblique tension poses a real risk of bendiing the derailleur or pulling it clean off if there is not enough chain length.
It's OK to have a little bit of slack in the small-small gear,
because the chain growth in some suspension designs requires it to ensure there's enough chain length to prevent damage in big-big under high suspension compression. It's very rare for suspension to be fully compressed when in that gear, but there are some people who do select gears & ride that badly that it's possible!
That's big big and about what it should look like
I would add that's how it should look in big-big
with the rear suspension in full compression. Stick it in that gear & deflate the shock, then cut your chain to suit.
