Specialized29er
Recently I purchased a used and rebuilt Specialised 29 MB that has a 2 x 9 Shimano Deore setup with 24t & 38t at the crank and 34t on the rear hub which is ok but nothing outstanding.
I've been told I can't go any lower at the rear without a new hub so I'm wondering which would be the best way to go.
The seller said the rear rim is 4 years old and it's an Alex HR Disc 29", alloy double-wall, disc, pin joint, 24mm, 36h whatever that means.
The rim is straight and has not been buckled so would I be better off buying a new complete Alex rim and hub with lower gearing or do I buy a new hub and gears and have this fitted to my rim.
I suppose it comes down to the cost of fitting the new hub and gears to my rim compared to buying a new complete rim.
What would be a good lower gearing combination that I could use and what would I achieve by using my 24/38t crankset with say 10 or 11 gears on the rear and would I need to change either one or both sprockets at the crank.
I'd also have nothing against changing the front and rear derailleurs/shifters if need be.
