sich nich
I bought my 08 MRD TPC Minutes a while ago when they were mega cheap from Dirtworks with the intention of lowering them from 130mm down to 80mm for my 4X/DJ bike. Stripped them down straight of the box, worked out where the spacer needed to go on the air spring rod, machined up a nice nylon spacer, and put it all back together.
Now, I've been putting up with this problem ever since, but it's time I cracked down on it. No matter how slow the rebound speed is, it seems to top out worse than I think it should. It's like a constant speed extending, then, *bonk* top out! Even when the fork takes like a whole second or two to extend, still tops out. Not a metallic top out sound, just a sudden one, not nice with a usual rebound setting.
The nylon spacer is a neat fit on the air spring rod, loads of clearance on the outside diameter, and the length determines how far it lowers the fork. It's positioned on the rod so it DOES engage/squish the rubber top out bumper, and I'm damn sure it doesn't block any ports or anything on the rod.
Is there a point of extension when the fork is 130mm travel where air from the spring chamber shares pressure with a negative chamber to smooth the topping out, and the lowered fork just can't reach that point? There is only one schrader valve on the fork, so I assume the pressure must automatically share into a negative chamber somewhere.
Using this fork for dirt jump has been OK with this problem, because I can mask it by having super slow rebound, super high pressure and the TPC round all the way on, almost making a rigid fork with a blow off. But I want it plusher now for different/non polished trails, and I'm just not getting it.
Any solutions anyone? Or do need to run 130mm for it to be schweet?
