That diagram looks kind of like my DJ3's.
Do you have a top out spring in there?
If so, lowering them can be piss easy.
So pretty much what i said should lower my forks?To lower mine, i just cut a spacer and put it on top of, or underneath, depends if your forks are upside down on the floor.
Lowers the forks and works perfect.
the spring will compress yes, but a spacer just takes up the amount it compresses keeping it the same height but making it bottom out earlieryeah the spring under the dampening rod is the top out spring im pretty sure?
and NH I get what your saying but wont sticking spacers under the damping rod compress the spring making the forks lower? I dont mind if they are hard, I would like that.
I get what your saying now.the spring will compress yes, but a spacer just takes up the amount it compresses keeping it the same height but making it bottom out earlier
