EsPeGe
Hi all I've got a bit on an issue with my 15 Mach 6 carbon. I've banged on the Push ElevenSix (it is AWESOME) and as a result had to change the cable routing to keep it clear of the coil. See below.
The problem is I've used a number of double sided tapes to fix the cable guides but they generally last between 1 and 10 rides if I'm lucky. This has led to some shifting issues as the shifter cable has room to flex and it's also really annoying. I don't want to glue them down permanently.
I've found a carbon bike repairer that can fairly easily put some custom ports in for internal routing which seems to me like the best solution. I know some folks don't like internal routing but for my set up I think it's the best solution.
What I want to know is if anyone out there has had experience with this and if so is there anything important I need to know before I proceed? I'm not concerned with the carbon guys, their work is nothing short of magic. Also are there any suggestions in regards to the actual routing? Should I follow the 16 mach routing or are there other options out there?
Finally I'm going to try to order some Pivot port covers but given this is a custom job this may not be an option. Are there generic grommet kits out there for this purpose?
Thanks heaps, Scott.
