cloudclone
can someone tell me wether the manitou stance kingpin are good or crap cause some of my freinds say they are mad but others say that they break and i cant make up my freken mind so can someone tell me
1 thing to say to you - shut the fuck up.KANE MCLATCHIE said:anythin manitou suck complete ass.
thats the stupidest thing ive heard since well... i cant rememberKANE MCLATCHIE said:anythin manitou suck complete ass.
Sorry to go OT but I'm wondering if this is a common problem on Skarebs as well? One seal on on a pair I've got appears to be lifting a little (topmost dust seal, is this equivalent to the main seal?).Juls said:3. Main Seals pulling out of the lowers, due to lack of lubrication (need constant lubing to stop this, all the stances suffer this)
if your lowers are lubed by grease, and not oil this is possible,notb4dinner said:Sorry to go OT but I'm wondering if this is a common problem on Skarebs as well? One seal on on a pair I've got appears to be lifting a little (topmost dust seal, is this equivalent to the main seal?).
Juls said:Problems:
1. Potential leg snappage under lower crown, even with light riders.
2. Reverse Arch Crown cracking/snapping
4. Lower Damper Leg rebound plunger rod seal blows easily, causing the fork to dump it's oil into the lowers, causing fork lockout, blown seals and or reduced available travel. Also eliminates rebound damping over time.
5. Air preload system causes fork to blow seals, does not work properly (must be replaced with firmer spring, and air preloader removed)
Bad things:
1. Weighs a ton
2. fork stanchion coating wears off very quickly, making the fork look crap
3. requires constant maintainence and relubing of legs/seals (fork is not open bath) or the seals pop out, and the action gets stiff.
4. 20mm dropouts can crack easily if aftermarket axle is used and possibly overtightend. (although if you overtighten any fork this can happen, it's more common the manitou design)
5. limited range of rebound damping adjustability if you try to use a different weight oil other than stock.
Good things:
1. When maintained properly the TPC + system can potentially feel and work quite well.
2. It looks reasonable I guess
3. Snappages are few and far between. (but still relatively common)
Suggestion.
Treat as a interim fork, don't treat as your one and only keep forever because it just isn't good enough for that.
regards
Juls
