Zac Hinton
St Bernard
Hi All
Just attempting to drop the lowers on these forks to replace fluid etc. I have done this before on these forks but this time is a bit harder. I can't get the rebound side lower Allen bolt out of the fork leg. It turns about one full turn and is then notchy, consistently. The fluid has drained, so it's definitely loose but won't pull out. It can even tighten up again fine, so not stripped.
Theres no info online about rebuilding these forks unfortunately. Probably extremely similar to 55cr forks. I have tried extending and compressing forks and that doesn't help.
For anyone else doing the same, you will need 15mls of 90 weight gear box oil for the air preload chamber (remove valve core to drain/replace) and 20-25mls of 7.5 weight for the lower legs ( mix 5 and 10 weight, bought from motorbike shop). Don't squirt any oil into the rebound cartridge, it will slowly drain out over time (out of the rebound adjuster). Fluid weights and volumes confirmed by Marzocchi USA tech dept via email.
Using an impact driver seems to be recommended, but I wanted to see if anyone else has dealt with this issue before I damage anything.
