Lucaw
Next in line
Item: heavily upgraded medium 2010 Specialized stumpjumper
Item Condition: mechanically sound, some heal rub on the back of the chainstay and many cosmetic scratches over the frame
Reason for selling: New bike!!! AM - Second Time Lucky (Craftworks FRX V2) | Rotorburn
Price and price conditions: $1200 or if you don't like that, negotiate with me
Extra Info:
selling my trusty steed as I have outgrown it. Has quite a few scratches and some heel rub but nothing that affects performance
It's a very fun bike that I have ridden all over the state including, derby, st Helens, penguin, wild meresy and lots of the Meehan range. Both me and the previous owner have heavily upgraded the bike and very few parts are stock.
it has a wider range 10-speed Shimano drive train that is 8 months old, 4 piston SRAM brakes that are 6 months old and a longer travel Marzocchi fork that is stiffer and more durable than the stock Fox
Specs below:
Frame - 2010 specialized Stumpjumper fsr comp size medium, had pivot bearings replaced in July 2020- 140mm of travel
Rear shock - fox triad 3 position shock, propedal, open and locked
Front shock/fork - 2005 Marzocchi am 1 -seals replaced in December 2020- 145mm of travel
Handlebars - crankbrothers colbat 3,
Stem - specialized 75mm
Saddle - WTB
Seatpost - ks lev, external actuation, 125mm of drop with upgraded 1 by lever
Front brake - SRAM guide r with 180mm rotor
Rear brake - SRAM guide r with 180mm rotor
Cranks - truvantiv hussufelt with 32 tooth narrow wide rsp cling ring
Chain - kmc x 10
Pedals - nukeproof neutron
Rear derailleur - Shimano Deore 10 speed long cage with goat link
Rear shifter - Shimano Deore 10 speed
Cassette - sunrace 10 speed 11-46 tooth, perfect for climbing
Front hub - Shimano
Rear hub - Shimano
Front rim - DT swiss 26 inch
Rear rim - WTB dual duty fr 26 inch
Tyres - maxxis high roller 2.35 X 26 front and schwalbe nobby nic 2.25 X 26 rear
Would make a great first dual suspension as it was for me
NOTE: The images of the specs show red grips, but these have been replaced with better black ones
$1200 ono - can sell cheaper without the dropper
may part out depending on what you want
check out my other listings
Pictures:
Extra Info:
Specs below:
Saddle - WTB
Chain - kmc x 10
Front hub - Shimano
Rear hub - Shimano
Pictures:
