Product Review Microshift XCD, 11 speed shifter & derailleur. Final update. Disappointing...
wkkie
It's Not Easy Being Green
Item:
Microshift XCD, SL-M861-R, 11 speed shifter.
Microshift XCD, RD-M865M, 11 speed derailleur.
Purchased From:
Worldwide Cyclery;
Purchase Price (approx):
Shifter - $29.70 USD
Derailleur - $57.60 USD
Usage:
More gravity fed riding, but also earning the descents. Currently running it on a Dartmoor Hornet hardtail.
Pros - Not SRAM or Shimano (but is listed as compatible with Shimano 11 speed gear, which may also mean it's interchangeable with SRAM 11 speed as well, no?). Competitive price. Competitive weight. Snappy lever feel. Works well. Good build quality. Easy setup.
Cons - Not readily available. Unproven warranty support (Microshift state 4 year warranty!), bar mount is not hinged for easy removal and installation.
Comments:
So far this has been sitting in my build box since about January. I only just got around to putting it on a bike this week
Initially the build quality looked good out of the box. Gloss cover on the shifter and a matte finish on the derailleur. The shifter came with an inner cable installed, so that was good.
The shifter is currently installed next to an XT M8000 brake lever and there's no issues with them conflicting, the shifter sits in snugly below the brake lever without any worries or looking out of place. The bar mount band itself is very low profile and neat looking. It uses the same 4mm boot head as the Shimano kit next to it. The downside to it is that it's not a hinged design, so the grips have to come off for removal.
The shifter is different ergonomically compared to the XT I've been running most recently. The shifting action itself is lower lever push for an easier gear and you can go up basically as many gears as you like with one long push of the thumb. The action is smooth, light and crisp. I would say it's a lighter action than the XT.
Shifting down to a harder gear is something different to the XT. You can only shift down one gear at a time, and only trigger style with the index finger. This is where I've had most issues. I've always change down with my thumb in all the Shimano shifters I've used, basically forever. So that took some getting used to.
The action itself is very instant and a positive firm click drops the gear fast. Multiple fast trigger pulls were also fast, and there was no lagging between shifts. Ideally I would have liked to be able to do more than a gear at a time, but it's certainly no deal breaker.
Reach wise, I have fairly large hands and I'm finding that there is no perfect spot for the paddles. Far enough out for my thumb to sit on the meaty part of the paddle and I have to cock my wrist to far for the downshifts. If the trigger for my finger is closer for less wrist movement, then the thumb paddle is too close.
I ended up finding a fairly happy medium, and I think it's just something that I'm not used to, the action of changing with the index finger. By the end of the first ride it was becoming more natural, and there were certainly no issues with hand fatigue, or pain, or anything to that extreme.
All up I'm happy with the shifting feel and speed of the shifter. A nice piece of kit.
The derailleur mounts directly to the hanger, not by way of a link like on the Shimano derailleurs. The mounting bolt is also a pivot point and there is a slight bit of play at that bolt, maybe half to one millimetre, but it didn't feel excessive and there were no problems with the installation.
The B limit screw sits directly on the hanger and I did notice when I was installing and adjusting it, it did take some paint of the hanger itself where they touched. I found it best to pull the derailleur body back, so the B limit screw wasn't touching the hanger when I adjusted it. I'm running a 10-42 SRAM GX cassette and there was more than enough adjustment left with the B limit screw. Microshift state it can take up to 46t.
The cable install is a straight path from it exiting the outer to the clamp point and the cable just clamped under a washer. Easy path, easy install. The whole derailleur is also tucked away quite nicely under the chainstay, very low profile, so should stay put of the way of the rocks and trees fairly well.
The derailleur runs a clutch which is activated by a switch on the face of the derailleur. There's an audible click from the clutch when the cage is moved and it's active and there a good amount of tension on the cage itself.
I'm currently running a chain which is probably at least 2 links too long and no chain guide. There were absolutely no issues with the chain retention on the hardtail. So far I've only ridden at the You Yang's, but some decently rocky sections on Cressy, the black section of Junction and Lactic and zero issues with the chain hanging on.
All up so far I would say that this is a great alternative to the 2 big S's and I would happily recommend them to others. Testing time is only short so far, but from the look of the build quality and the function so far, send to be a quality piece of kit. Time will tell...
Pictures/Videos: I've taken a few so far (not all that great, but hopefully passable), but will take some more, thinking about the mounting and cable lines that would be good to show;
353122
353123
353121
353125
353124
353127
Thanks indeed, definitely on my radar now. I prefer the thumb/ index finger style of shifting, and don't mind that the downshift is limited to one gear at a time. Currently running XT M8000 and I occasionally overshift with the index finger as the XT trigger allows a double downshift. It'll be interesting to hear how you get on with longevity. I have no desire to move up to 12 speed as several of my riding buddies have clobbered and bent Eagle derailleurs, so anything compatible with current 11 speed standards is a good thing in my book.
But of an update, the gear has all been transferred to the Blackbird dually frame.
This time around the derailleur is running with an XT shifter. It was nice to have the thumb downshifting back.
It was run at Maldon, so not a heap of changing going on, but it did play nicely with the XT shifter on the shifts I did do.
When I put the bike together I ran out of time to find the chain guide. I dropped the chain 3 times during the day and twice it was lightly stuck in the lower jockey wheel and it's cage.
Not sure if that's a derailleur specific issue or not, but didn't have the issue with the XT. Saying that though, I can't remember dropping a chain with it because I've always run the guide.
Should be able to find the guide for the future, so will update if the lower jockey wheel jams continue.
TLDR: It plays nicely with the XT shifter. :)
Some more time passed and still shifting nicely with the XT shifter.
A few things to note. Last ride the mounting bolt was almost entirely unthreaded from the hanger. Luckily I was having other issues, so this was picked up before major damage to anything. Infact, there was no damage to anything, and it was still shifting precisely the entire time.
I have had more drops though. The chain is dropping off the lower jockey wheel. For some reason the cage flanges out and creates room for the chain to jump off and sticks between the jockey wheel and the wall of the cage.
I was origin thinking it may have been due to no top guide, but I don't actually think that's an issue anymore.
I did check to see if the jockey wheel is directional, like the XT M8000, but made no difference when I flipped it.
I'm going to put some rubber tape in the gap to reduce the clearance and hopefully that'll stop it dropping off and dumping the chain altogether.
354168
354169
Bit more of an update and it's not looking as promising as it was initially.
Good news is that the chain stopped dropping, but only due to filing the gap with the 3M rubber tape. I spoke to Worldwide Cyclery and they checked on another they had in stock and said the gap is the same.
Here's my fix...
354453
I've also discovered another issue with the inner cable and it's path from the exit of the outer to the clamping bolt.
It looks like the angle is much to great and what's happened is that it's carved a groove in the exit port which has 2 metals joining at that point and created a sharp edge which just ate through the cable.
This is the result from less that 70km where a brand new inner was installed.
354455
354454
354456
At this point I'm still waiting to hear back from Worldwide Cyclery in relation to the derailleur.
Given the issues I've had with it so far, it's hard to recommend this. I don't do a massive amount of kilometres and to have it get to this point from not a huge amount to use is disappointing.
