can someone explain to me midstroke support and its relation to HSC and LSC. I know what it is but how does it relate to the other adjustments. From what I have gathered from my RC4 midstroke is sort of support essential while HSC is more initial compliance not really a support adjustment.
Right now my boxxer R2C2 feels nice but while it uses appropriate travel in rock gardens as soon as I launch off into a rock gardens it likes to blow through its travel. HSC is fine as it uses the right amount when not launching. My LSC is also nice but due to the fork wallowing a fair bit in bigger holes I run it fairly stiff which takes away a little traction on the smaller stuff like corners. I can only think that I need some midstroke to help support the lsc and hsc. Is this a correct assumption?
Do I achieve this with shim stacks or am i looking at a custom damper
Settings
spring :yellow soft (63-72kg) the recommended was undersprung
LSC +10
HSC +8
ESR 14 from full slow (ESR 7 from fast)
BSR 17 from full slow (BSR 8 from fast)
Ideally id like to run slightly less LSC to get more traction early on but have more support midstroke so it doesn't dive too much, HSC I dont want to go too high to lose that initial compliance id like a little more sport.
i haven't really tested my rebound much so maybe that might help? I cant see how though given rebound doesn't offer any opposing force or resistance to compression.
Settings
LSC +10
HSC +8
