BT180
Max Pfaff
Anyone using these? Need some new pads for my Juicy 5s (Yes, I know).
http://miles-racing.squarespace.com/
Any good?
Any good?
Any good?
Select your country and the pads for different brands will be shown.hi could you list all the model brake pad's they make ,
the web site don't not show any models, be side Semi-Metallic/Semi-Metallic on Alloy Plate/Sintered are all blank thank you
Hey Tomac,hi could you list all the model brake pad's they make ,
Definitely don't mix two types of pads, will just make one pad wear faster than the other and won't displace the heat correctly.I've read of a number of folk running different pad material on each side of the caliper (e.g. shimano resin on one side of disc, metallic on the other). Apparently the best of both worlds.
Would be interested to know, from someone with product knowledge, whether this is BS, and if not, whether the same would be applicable for the two options Miles has for Saint 810s ... Sintered and semi-metallic.
