I have an X-Fusion one I think if you’re interested.I thought of that. But I've got 2x 30.9 droppers already and 27.2's are a little hard to come by at the moment.
I am interested. Very interested.I have an X-Fusion one I think if you’re interested.
Ok will check when I’m back.I am interested. Very interested.
Thanks Tubbsy.Ok will check when I’m back.
It's off an AH Astra. I have a steering column, was just hoping I could get by without having to hack it up. I attempted dissasembly today, looks like I'm going to have to get the angle grinder out.@wesdadude what car is the steering shaft off? An option couldnbe a shaft from a wrecker cut and threaded or welded to a blank. What is the pcd of the flange?
#<CAP_DIA> = [30.5]
#<CAP_RADIUS> = [#<CAP_DIA>/2]
#<LOBE_DIA> = 14.25
#<LOBE_RADIUS> = [#<LOBE_DIA>/2]
#<LOBE_SEPARATION> = [17.5+#<LOBE_DIA>]
#<center_offset> = [#<LOBE_SEPARATION>/2*SIN[45]]
G2 X[#<center_offset>-#<LOBE_RADIUS>] Y[#<center_offset>] I[0] J[#<LOBE_RADIUS>]
G1 Y[#<CAP_RADIUS>]
G1 X[-[#<center_offset>-#<LOBE_RADIUS>]]
G1 Y[#<center_offset>]
G2 X[-#<center_offset>] Y[#<center_offset>-#<LOBE_RADIUS>] I[-#<LOBE_RADIUS>] J[0]
G1 X[-#<CAP_RADIUS>]
G1 Y[-[#<center_offset>-#<LOBE_RADIUS>]]
G1 X[-#<center_offset>]
G2 X[-#<center_offset>+#<LOBE_RADIUS>] Y[-#<center_offset>] I[0] J[-#<LOBE_RADIUS>]
G1 Y[-#<CAP_RADIUS>]
G1 X[#<center_offset>-#<LOBE_RADIUS>]
G1 Y[-#<center_offset>]
G2 X[#<center_offset>] Y[-#<center_offset>+#<LOBE_RADIUS>] I[#<LOBE_RADIUS>] J[0]
G1 X[#<CAP_RADIUS>]
G1 Y[#<center_offset>-#<LOBE_RADIUS>]
G1 X[#<center_offset>]
