G
Guest
Guest
http://www.pinkbike.com/modules/photo/?op=view&image=109185
demo 9 pro...has this taken over the bighit?
no its not as the bottom bracket isnt on the chainstayCHEWY said:very nice, is it just me or does that look like it has URT ?
If you look at any full-linkage bike... they all work like that. It's just the difference in pivot placement that makes all the diff.Kram said:If you stare at it long enough, it starts to look like a V10.
No kidding, look closely and imagine how the 2 linkages interact. The V10 has a much smaller "inner" linkage, but the number of pivot points and the relationship between them is the same, just to a different scale. The wheel axle pushes up on the top linkage, whilst pulling on the bottom linkage which acts like it's own single pivot swingarm against the shock. On the V10, that's the black onodised piece that is almost hidden behind the crankset, so relative size is very different, but the action is the same. Ummmm am I making sense? Anyway, look closely and judge for yourself.
The wheel does (or might as well) follow the same path as a singlepivot (albeit with the pivot in a location that isn't necessarily the same as the main pivot on the current linkage). Until you start incorporating pretty drastic backwards (eg Canfield's Fatty Fat Fat) or forwards elements (none that I can think of, maybe a Giant NRS), most bikes may as well be singlepivots for their axle path.RaID said:no its not as the bottom bracket isnt on the chainstayCHEWY said:very nice, is it just me or does that look like it has URT ?
plus the wheel doesnt follow the same path as a single pivot
I disagree. A regular 4 bar linkage pushes the shock from the top linkage plate. An intense and a norco and a big hit are all alike enough to require patent rights from Special Ed, because the forces are all applied in the same manner. You can position the pivots wherever you like within this paralellogram, but you will still be infringing on their patent. My first generation chromo FSR had the pivots in vastly different places to the current big hit, but it was still a 4 bar.Socket said:If you look at any full-linkage bike... they all work like that. It's just the difference in pivot placement that makes all the diff.
