Never. I always leave at 160mmHow much do you use the DPA?
Is it worth your trouble to swap to a SA? opens up a bunch more options for tuning the spring rate (mrp which is just on the fly token adjustment really, luftkappe, AWK etc)Never. I always leave at 160mm
Could be. It's certainly food for thought.Is it worth your trouble to swap to a SA? opens up a bunch more options for tuning the spring rate (mrp which is just on the fly token adjustment really, luftkappe, AWK etc)
Otherwise theres a few coil conversions getting around these days for a similar amount of coin? The TF Tuned one will run in DPA or SA forks.
Look I mean, if were talking about total fork upgrades, the mattoc is a worthy contender at almost half the price of the diamond as well.Mate I hated my Pike DP partly because I was stuck with no upgrade option for the air spring. Coil was out of the question as it would be irreversible. Also I never used the lower travel setting.
Ended up getting a DVO Diamond and am rapt it also fixed several other issues I was having with the Pike.
Ask yourself do you want to pay for a Solo which really doesn't give you anything more but an air spring upgrade option.
It's certainly not worth changing it to a solo that's for sure. Just a shame there is so limited options for the DP like you say.Mate I hated my Pike DP partly because I was stuck with no upgrade option for the air spring. Coil was out of the question as it would be irreversible. Also I never used the lower travel setting.
I'm happy enough with it to not warrant a complete fork change and the coil spring is a no go for the reason that Tek said. I'll save my money for a bike upgrade in a couple of years instead....Look I mean, if were talking about total fork upgrades, the mattoc is a worthy contender at almost half the price of the diamond as well.
It won't work with a DPA fork, it relies on the air chamber dimple on the solo air stanchion to equalise the negative and primary positive chambers. The DPA fork doesn't have this and nothing on the site suggests how they've overcome that issue?This may interest you, though I'm not sure it will be within your price range or not.
Replaces the entire Dual Position air spring with a DVC (basically a variable volume token) & allows you to independently adjust primary positive, secondary positive & negative air springs.
The kit doesn't come with a Solo Air shaft, but does come with an adapter to make it work.
Check out the website for more information: https://www.sdcomponents.com.au/dynamic-volume-chamber
Yes, it's looks a bit more than I want to fiddle with anyway. I liked the idea of the MRP because I think I'm somewhere between 2 and 3 tokens on my fork and liked the idea of fine tuning without pulling it apart.It won't work with a DPA fork, it relies on the air chamber dimple on the solo air stanchion to equalise the negative and primary positive chambers. The DPA fork doesn't have this and nothing on the site suggests how they've overcome that issue?
It's also more complex than simply an adjustable token system, which is more or less what the MRP unit actually is, it's actually allowing you to tune the start and end of the spring rate independently where as tokens/ramp controll tie those two things together.
I try not to give in to the voices.....Are you unwell?
Cut a token in half.Yes, it's looks a bit more than I want to fiddle with anyway. I liked the idea of the MRP because I think I'm somewhere between 2 and 3 tokens on my fork and liked the idea of fine tuning without pulling it apart.
And I was so close to buying myself that Bell helmet you have for sale....Cut a token in half.
You're absolutely right in that regarding the air chamber dimple. That issue is solved by modifying the air shaft. It's very much a hack job though, hence why that particular kit combo isn't listed on the website.It won't work with a DPA fork, it relies on the air chamber dimple on the solo air stanchion to equalise the negative and primary positive chambers. The DPA fork doesn't have this and nothing on the site suggests how they've overcome that issue?
