Yep, it makes the wheelsize changes more obvious.I saw that but I reckon hardtail vs rear suspension would have an effect too.
I hear you. Was just curious. And read the Sapphire was a nice fork anywayI mulleted my GG Megatrail. Only because I couldn’t make it a full 29er.
For various reasons I couldn’t get along with it. I suck at explaining technical aspects of bike feel so can’t give you much of run down of my findings.
I think if I’d mucked around with it more changing bits and pieces here and there to get it right it would work especially as this bike is well know to make a good mullet but I don’t have the patience. I’m more of I just wanna ride the thing not fettle with it every ride.
So you might throw a wagon wheel on the front and it’s good to go but I’d say don’t expect not to have to play around with it a fair bit, and it still may not ever feel great.
Cheers man. Definitely not off the cards, just need to find a suitable forkI've built a couple of bikes up as mullets.
The first was my nicolai g16, originally had 27.5 wheels but got mullet curious as it's the best of both worlds and many people on mtbr ran this combination. Only thing I did when swapping over was reduce the travel on the fork by 10mm to bring the a2c down by 10mm. I much preferred this setup to 27.5.
The second was a v3 spitty. Got a good deal on the frame but couldn't go back to a 27.5 front wheel after experiencing the bigger wheel up front. So mulleted it also, I never ran this as a full 27.5 so can't compare. Also I sold it shortly after building it as I rode an ebike and was converted.
I'd say go for it. If you have a fork that you can adjust travel without a new air spring you can experiment a little to find the sweet spot.
New build I'm on the fence between full 29 or mullet again. Probably go mullet, I'm not racing and in it for fun with lots of jumps.
I really like how playful the mullet setup is and it suits my regular trails perfectly.
Sent from my Mi 9T using Tapatalk
I found the easier spin up of the rear 27.5 wheel was more beneficial and noticeable than the detriment of the slightly slacker seat angle.. I even have some PB's still remaining from this set up on the climbs..That too. I was wondering if any fellow mulleters thought the negative climbing and flat terrain bobbing of their bike after mulleting made it not worth while
August earliest....when do you expect t see it?
Who are you, the rumour patrol?Are you telling us you are going to transition some mystery bike from mullet to full 27.5?
You going to get excited and put a big 180mm fork up front or just go full @Daniel Hale and rock the steepened head angle?Who are you, the rumour patrol?
Apparently the new Patrol needs a 200mm 650b fork to keep the equivalent geometry so dual crown or go home.You going to get excited and put a big 180mm fork up front or just go full @Daniel Hale and rock the steepened head angle?
Fella in my category at Bright was rocking a Meta AM with a Boxxer up front. He was very fast that day. Did look like a pretty dope set up.Apparently the new Patrol needs a 200mm 650b fork to keep the equivalent geometry so dual crown or go home.
180 is the number needed to balance it out, but I think 170 would be plenty without affecting too much. Haven’t decided yet.You going to get excited and put a big 180mm fork up front or just go full @Daniel Hale and rock the steepened head angle?
Might be a bit awkward on some tight switch back climbs.Fella in my category at Bright was rocking a Meta AM with a Boxxer up front. He was very fast that day. Did look like a pretty dope set up.
