Tomshak
Got it today and it is brilliant
All is as stock
Bike: '09 Norco Sasquatch
frame: Hydraform alloy frame with forged yoke, added gussets, low stand over
fork: Marzocchi 55 RS, 160mm of travel, 20 mm axle, 1-1/8” steer tube
rear shock: N/A
headset: FSA TH-855 MTB 1-1/8”
crankset: Truvativ Hussefelt crank 34/24T, 170 mm, Black
bottom bracket: Truvativ Howitzer spline
pedals: Alloy flat pedal, sealed bearing, steel pins, custom colour
chain: KMC Z-9000 9 speed
cassette: Sram PG-950, 9 speed, 11-32T
front derailleur: Shimano Alivio
rear derailleur: Sram X-5, 9 speed, medium cage
shifters: Sram X-5 trigger, 9 speed front and rear
bar: Truvativ Hussefelt Comp alloy, 38 mm rise, 31.8mm
stem: Truvativ Hussefelt alloy, 31.8mm, 40mm extension
grips: MTB krayton grip
front brake: Avid Juicy 3, 7” rotor
rear brake: Avid Juicy 3, 7” rotor
brake levers: Avid Juicy 3
front hub: KT 20mm axle, sealed bearings
rear hub: KT alloy disc, 8/9 spd cassette
rims: Sun Single Track double wall, 32 hole, painted
spokes: Stainless steel black 2.0
tires: Kenda Nevegal 26 x 2.35, Stick E rubber
saddle: Norco Shore, short profile, custom cover
seatpost: Truvativ XR double bolt, 30.9
Cheers,
Carl
All is as stock
rear shock: N/A
Cheers,
Carl
