Lucaw
Next in line
This is the hardtail that I started to build after I was given a frame in the lockdown of 2020. it has gone through many iterations since I first built it but I'm finally happy with the build so I decided to put up a PYR. This was the bike that I reamed out the seat tube to fit a dropper. It's very short and jumps well but might be getting a tad small for me. I have ridden it in Derby, St Helens and trails around Hobart
Frame - 2007 Norco Maink size m, reamed from 30.0 to 30.9 and drilled to accommodate an internal dropper post
Front shock/fork - marzochi 55 tst
Handlebars -nuke proof warhead 740mm
Stem -Truvantiv holtzfeller 35mm stem
Headset - FSA top, aerozine bottom
Grips - canyon
Saddle - wtb
Seatpost - funn up down
Front brake - Shimano m775 with avid 203mm csg2
Rear brake - Shimano m775 with avid 203mm csg2
Cranks - ride raceface forged with 34 tooth blackspire snaggle tooth
Chainguide - e*13 top and bottom with taco bash
Chain - sram 8 speed
Pedals - rockbros
Rear derailleur - microshift acolyte 8 speed clutched
Rear shifter - microshift acolyte
Cassette - 12-46 microshift acolyte
Front hub - novatec
Rear hub - good question
Front rim - alexrims supra bh
Rear rim - sun rims ditch witch
Spokes - less then there should be
Nipples - yes
Tyres - minion dhf front, Highroller 1 rear
Tubes - yes
Total weight - yes
Grips - canyon
Saddle - wtb
Pedals - rockbros
Front hub - novatec
Nipples - yes
Tubes - yes
Total weight - yes
