Mad4singletrack
My Mountain
Yeti Cycles SALE @ My Mountain in Melbourne!!
Well you've heard about the SB95 Deal we recently unveiled, but the big news this week is that we're adding several more models across the range to make for a full-blown Yeti Bikes sale. If you've been thinking of making the leap into the Yeti Tribe, now is your only chance to get onto an ASR 5 Alloy, an ASR 5 Carbon, a 575 or the SB95 for a price that will NEVER be seen again!
We often make no mistake that Yeti Cycles produce boutique bikes with a level of quality and suspension technology unmatched by the mass-produced brands, but for a limited time only you can get that same quality without the boutique pricing. It's only while stock lasts though, and with sale bikes already flying out the door, numbers are EXTREMELY LIMITED!!
Not from Melbourne? No problems - we can help you organise shipping of your brand new Yeti Bike straight to your door, just get in touch with us via email (tim@mymountain.com.au) or phone (03 9388 8678).
Yeti ASR 5 Carbon Ex-Demo RRP: $6699
Our Price: $4908.38!!
From My Mountain:
"The introduction of the carbon fiber ASR-5 has redefined what to expect from a superlight dual suspension mountain bike. At just over 2kg for the frame w/shock, the ASR-5c is an incredible piece of engineering and especially so when you factor in the oversized construction and capable low-slung geometry. Most bikes around this weight are strictly for race use only, but the ASR-5c is built for maximum fun factor on technical trails that would leave most other bikes feeling nervous and under-gunned. As it's name suggests, the ASR-5 provides 5" of smooth Fox-controlled suspension using..." read more here.
The ASR 5 Carbon features:
- Hi Modulus Carbon Fiber Main Frame & Rear Triangle
- Titanium Pivot Hardware
- Forged & Machined Suspension Links
- 127mm (5") of rear travel
- Designed for 120-140mm travel forks
- Fox Float RP-23 Kashima Rear Shock
- Tapered Headtube
- 142x12mm Thru-Axle
- 73mm English Threaded Bottom Bracket
- Seatpost diameter: 30.9mm
- Front Derailleur Spec: 34.9mm Clamp, Traditional Mount, Bottom Pull
- Weight: 2150 grams (4.75 lbs) with shock
Shimano Deore XT - Race Build Kit
The most popular build kit of the range, the Shimano XT-Race groupset drops weight over the Easton kit and adds a few more tricks to the ensemble. Whilst the XT drivetrain and brake set remain, Yeti also utilise a lighter handbuilt DT Swiss wheelset that rolls on the bombproof 350 hubset that's laced to Tubeless Stans Arch EX rims. To match the rest of the bike, Yeti have also gone and decorated the XT kit with a beautifully machined Thomson post, a lightweight Haven Carbon handlebar and they've even specced the higher quality EVO tyres from Schwalbe with a Tubeless Ready casing. All up, there are very few parts on the XT kit that you could upgrade and realistically, you're getting very close to the performance of XTR at only a slight weight penalty.
- Fox 32 Factory Float 140mm CTD w/Trail Adjust, Kashima Coat, QR15, Tapered
- Full Shimano Deore XT 2x10 speed Drivetrain w/ 2-piece 38/26t crankset
- Shimano Deore XT Ice Tech Brakeset w/160mm front & rear Rotors
- Custom Handbuilt DT Swiss Wheelset w/350 Hubset and Stans Arch EX Tubeless Compatible rims
- QR15 Front & 142x12mm Thru-Axle
- Schwalbe Racing Ralph 2.25" EVO Tubeless Ready SnakeSkin Tyres
- Easton Haven Carbon 711mm Bars, Thomson Elite Seatpost & X4 Stem, WTB Rocket V Saddle & Yeti Lock On Grips
Yeti ASR 5 Alloy RRP: $5799
Our Price: $4148.02!!
From My Mountain:
"Utilisng the AS-R suspension design, the '5' gets 127mm of rear travel courtesy of a custom-valved Fox Float rear shock. Up front, the AS-R 5 sees a gold Kashima-coated Fox fork with 140mm of travel and the CTD damper adjustments that allow you to select between 'Climb', 'Trail' and 'Descend' settings depending on the trail in front of you. Yeti bikes have always been exceptionally well balanced, and combined with its modern geometry that sees a slacker head tube angle than normal, the ASR5 is far more composed..." read more here.
The Yeti ASR 5 Alloy features:
- Custom Alloy Tubeset with Hydroformed and Butted profiles
- Hi-Modulus Carbon Fiber One-piece Rear Triangle
- Titanium Shock Hardware
- Fox Float RP2 Boost Valve Rear Shock
- Tapered Headtube
- Optional Dropouts for 135mm QR or 142x12mm Thru-Axle (135mm as standard)
- Weight: 2500 grams (5.5 lbs) with shock
Shimano Deore XT Build Kit
The most popular build kit, the Shimano XT groupset steps up the shifting and braking quality whilst also dropping weight too. Aside from the change to the XT drivetrain and brake set, Yeti also utilise a lighter handbuilt DT Swiss wheelset that rolls on the trick SRAM X9 hubset that's laced to DT XR400 rims for a low overall weight. To match the rest of the bike, Yeti have also gone and decorated the XT kit with a beautifully finished Truvativ Stylo cockpit and they've even specced the higher quality EVO tyres from Schwalbe with a lighter casing and higher quality rubber. All up, there are very few parts on the XT kit that you could upgrade and realistically, you're getting very close to the performance of XTR at only a slight weight penalty.
- Fox 32 Float 140mm CTD w/Trail Adjust Factory Fork, Kashima Coat, Tapered
- Full Shimano Deore XT 2x10 speed Drivetrain w/ 2-piece crankset
- Shimano Deore XT Ice Tech Brakeset w/180mm front & 160mm rear Rotors
- Custom Handbuilt DT Swiss Wheelset w/SRAM X9 Hubset and DT Swiss XR400 Rims
- QR15 Front Thru-Axle and 142x12mm Rear Thru-Axle
- Schwalbe Racing Ralph 2.25" EVO Tyres
- Truvativ Stylo T30 Post, Bars & AKA Stem, Cane Creek 40 Headset, WTB Rocket V Saddle & Yeti Lock On Grips
Yeti 575 - XT/Easton Build Kit RRP: $5899
Our Price: $4163.07!!
From My Mountain:
"One of the very first long-travel trail bikes to hit the market almost a decade ago, the Yeti 575 was a glowing example of the brands innovation and investment in R&D into both frame and suspension development. Originally bursting onto the scene as a durable and plush trail bike that could double-duty as an endurance race bike, the modern incarnation of the 575 has seen a number of improvements to..." read more here.
The Yeti 575 features:
- Custom 7005 Alloy Tubeset with Hydroformed and Butted profiles
- 146mm (5.75") of rear travel
- Designed for 140-150mm travel forks
- Tapered 56/44mm Headtube
- Optional Dropouts for 135mm QR or 142x12mm Thru-Axle (142mm as standard)
- Front Derailleur Spec: Low Direct Mount (E-Type)
- Weight: 3170 grams (7.0 lbs) with shock
Shimano Deore XT - Easton Build Kit
New for 2013 is the introduction of a new XT-level build kit that comes decked out with an array of Easton components. The big news with the Easton build is the addition of the excellent EA70 XCT wheelset that features UST Tubeless compatibility for easy tubeless setup with the Schwalbe tyres. While the EA70 wheels are lightweight, they use a generous internal width that provides a stable platform for the 2.25" wide tyres. Keeping inline with the wheelset, the XT-Easton is finished off with a high quality Easton EA70 cockpit that's complete with Yeti lock-on grips and a WTB Rocket V saddle. What is perhaps most surprising with the new XT build kit is the price, being one of the best-value kits for you to dress up your new frame with. Quality tubeless wheels, a flawless Deore XT drivetrain and Ice Tech hydraulic disc brakes - what more could you want?
- Fox 32 Float 120mm CTD w/Trail Adjust Fork, Kashima Coat, Tapered steerer, QR15, Factory Series
- Easton EA70 XCT UST Tubeless Wheelset
- QR15 Front & 142x12mm Rear Thru-Axle
- Easton EA70 Bars, Seatpost & Stem, WTB Rocket V Saddle & Easton Lock-On Grips
Yeti SB95 RRP: $5800
Our Price: $4690!!
From My Mountain:
"Get set to swing your leg over what is possibly the most highly regarded bike of the season - the 29er SB95 from Yeti Cycles. With 5" of travel courtesy of the already proven Switch suspension design and the ability to take up to 140mm forks up front, the SB95 is a uniquely capable All Mountain 29er in a market filled with..." Read more here.
The Yeti SB95 features:
- Switch Technology: Fully Sealed Eccentric System
- Fox Float RP23 Adjust Boost Valve Kashima Rear Shock, Factory Series
- Oversized Pivot Pins with Enduro Max Cartridge Bearings
- Tapered 44/56mm Headtube
- Splined BB Shell for use with ISCG03/05 Chainguide Tabs
- Front Derailleur Spec: Direct Low Mount (E-Type)
- Weight: 3400 grams (7.5 lbs) with shock
