http://singletrackworld.com/2014/04/ibis-launch-three-new-carbon-fibre-wheels-and-rims/
Available in any size as long as its NOT 26"!
xc and enduro are 2 different things... you wont be using a 41mm wide rim for xc duties.Hi Guys,
Has anyone had a chance to try these out yet? I'd be interested to hear some feedback, as they are quite pricey to take a gamble on. I'm not aware of any other xc/enduro rim this wide, but I could be wrong.
Cheers,
Pete
I can't believe after 11 years that this is your 1st post.:ranger:Hi Guys,
Cheers,
Pete
Be very keen to hear some feedback on the Derby rims once you get some k's on them.Suggest you do a search for "Derby Rims", which are the rims Ibis based theirs on (they're mates with Derby apparently and foot some of the bill for his rims). Very good reports by all accounts; I've just built a set up but have only had one short ride on them so lot enough to give a serious opinion. They are certainly well made and built up nicely.
If you want something not quite as wide check out the Syntace W35MX's; they're 35mm outside/30mm inside, almost as light as carbon rims, and they're without doubt the tightest factory-built wheels I've ever seen. HUbs are great too, very light, adaptable to various standards, and have a star ratchet freehub.
FWIW
I got the HD rims as they're very light either way, and for the sake of a few grams I'd rather go with extra strength. FWIW, I built the 650B's (HD) up with Sapim CX-Rays, alloy nipples, and Syntace MX hubs; 770gm front and 810gm rear is pretty crazy weights for a rim of such girth! A friend of mine also has the same rims but in lightweight layup; he's been riding them for about 2 months and things seem to be going pretty well so far...Be very keen to hear some feedback on the Derby rims once you get some k's on them.
Heard great things on them and wonder how they go as a trail bike wheel. Got an email from Derby saying they will have more available in about 3 weeks.
did you get the xc or heavy duty rims?
I am testing these wheels at the moment. Only done 4 rides, but a few initial comments...Hi Guys,
Cheers,
Pete
Read a good review of these on PinkBike yesterday which reflects your commentsI am testing these wheels at the moment. Only done 4 rides, but a few initial comments...
- You must use round profile tires; HR2 and Magic Mary don't work. They become way too square and wide.
- Wheel stiffness and acceleration is impressive
- I am 95kg and I can comfortably ride 18psi fr 20psi rr.
- Width + low pressure = great traction and low rolling resistance. and great stability in corners even at low pressure.
- I love the feeling on roots and small bumps with the wide contact patch and low pressure.
I am definitely a wide rim believer now, the handling is fantastic. Can't comment on reliability strength yet though, and just be sure you get appropriate tires!
Thanks for the meaningful reply Horsey, great to hear someone backing up what the manufactures claim. What tyres did you end up settling for?I am testing these wheels at the moment. Only done 4 rides, but a few initial comments...
Depends on where you ride, unfortunately I don't have a stable of bikes at my disposal, so something that crosses into both categories is what i'm after. I was more interested in feedback on the 928 rims that would be more fitting than the 41mm wide rims.xc and enduro are 2 different things... you wont be using a 41mm wide rim for xc duties.
Cheers, I'd like to think that I find myself too busy having fun riding than to be sitting in front of my computer on these forums. Haven't really used this much since I joined in the farkin.net days. Just looking for some meaningful feedback on wide rims.I can't believe after 11 years that this is your 1st post.:ranger:
Haven't been able to test a lot of different tyres. The magic mary simply did not work, HR2 I was advised in advance is also too square. I have been riding with a 2.3 Minion DHF EXO TR on front, and a 2.35 SG Hans Dampf on the back. This combination works really well.Thanks for the meaningful reply Horsey, great to hear someone backing up what the manufactures claim. What tyres did you end up settling for?
An update to this review...I am testing these wheels at the moment. Only done 4 rides, but a few initial comments...
interesting....Update...
The rear rim cracked around the valve hole, I will admit I gave this wheel some solid abuse, but the crack is clearly a manufacturing defect as the the crack is right along where the rim is joined.
