New forks for DJ hardtail (around $250)
richie_gt
I’m looking to upgrade the forks on my hardtail as the original forks are goneskis! The bike is a DJ style hardtail but I use it mostly to commute to work, occasionally ride it off road on small jumps/pump tracks etc.
At this stage I’m prepared to spend a bit of money (around $250) on new forks as I don’t want to inherit someone else’s problems (i.e. someone pulling them apart not knowing what they are doing!)
I found Marzocchi DJ3 @ CRC for $235:-
http://www.chainreactioncycles.com/...gclid=CMeo96KX5cMCFRUHvAod8UoAlA&gclsrc=aw.ds
Any other recommendations?
Seriously, I understand where you're going but you're far better off looking in the fork section here. $250 will get you a much better set of forks than those...
I don't disagree with you but are the DJ3's really that bad? Surely couldn't be any worse than the dodgy worn out Suntour forks I have now!
True but you could get a set of CTD floats for $250 at the moment..
That's a good space to be in given the wide range available. Best just grab a whole wheel rather than rebuild.
