NPWS ranger powers
shore_2
Not that i condone the following activity it's just a question.
If i was on my MTB and accidentally rode a trail i wasn't meant to and got pulled up by a NPWS ranger what powers do they actually have to: Arrest, detain and make you give them your information. What stops you just fobbing them off and continuing on your merry way?
hifiandmtb
Sphincter beanie
Personally knowing park rangers, I do know they mostly don't want to get into any sort of confrontation. So if you act like a scary person, they will just let it go.
If you admit you are doing something wrong, dismount & walk the rest of the way I doubt they'd take it any further.
Mattydv
To the best of my knowledge, nothing. They usually try and get rego plates or other identifying features from which to send off fines.
This is the action to take, however.
cobba
Rangers have the power to arrest you if you don't give your name and residential address when asked, they can also arrest you if they suspect that you're giving false details.
http://www.environment.nsw.gov.au/legislation/Index.htm
http://www.legislation.nsw.gov.au/maintop/view/inforce/act+156+1997+cd+0+N
http://www.legislation.nsw.gov.au/maintop/view/inforce/subordleg+427+2009+cd+0+N
http://www.legislation.nsw.gov.au/maintop/view/inforce/act+80+1974+cd+0+N
Protection of the Environment Operations Act 1997 No 156
204 Power of authorised officers to demand name and address
(1) Name and address to be given if offence suspected
An authorised officer may require a person whom the authorised officer suspects on reasonable grounds to have offended or to be offending against this Act or the regulations to state his or her full name and residential address.
(2) Name and address to be given in connection with noise
If an authorised officer forms the opinion on reasonable grounds that a noise control notice or a noise abatement direction may be issued under Part 8.6 against a person, the authorised officer may require the person to state the person’s full name and residential address.
(2A) Proof of name and address
An authorised officer may request a person who is required under this section to state his or her full name and residential address to provide proof of the name and address. It is not an offence under section 211 to fail to comply with any such request.
(3) Power of arrest
A person who, being required to do so under this section:
(a) refuses to state his or her name or residential address, or
(b) states a name or residential address that in the opinion of the authorised officer is false,
may without any other warrant than this Act be apprehended by the authorised officer and taken before a Magistrate or authorised officer within the meaning of the Criminal Procedure Act 1986 to be dealt with according to law.
(4) Bail
A Magistrate or authorised officer before whom a person is taken under subsection (3) may grant the person bail in accordance with the Bail Act 1978 as if the person were accused of an offence.
(5) Maximum penalty
The maximum penalty for an offence under section 211 in connection with a requirement under this section is 100 penalty units despite anything to the contrary in that section.
National Parks and Wildlife Act 1974 No 80
156B Powers of authorised officers
(1) The Director-General may appoint any person (including a class of persons) to be an authorised officer for the purposes of national parks legislation. Such an appointment is to be made under Chapter 7 of the Protection of the Environment Operations Act 1997 (the POEO Act) as applied under this section.
(2) An authorised officer has and may exercise the functions of an authorised officer under Chapter 7 (except Part 7.6) of the POEO Act for the following purposes:
(a) for determining whether there has been compliance with or a contravention of national parks legislation,
(b) for obtaining information or records for purposes connected with the administration of national parks legislation,
(c) generally for administering national parks legislation.
(3) The provisions of Chapter 7 of the POEO Act apply to and in respect of national parks legislation as if those provisions were part of this Act, but modified so that:
(a) references in those provisions to an authorised officer were references to authorised officers appointed as referred to in this section, and
(b) references in those provisions to “this Act” were references to an Act or regulation forming part of the national parks legislation, and
(c) references in those provisions to the EPA were references to the Director-General, and
(d) the Director-General were the appropriate regulatory authority for matters concerning national parks legislation.
(3A) Section 319A of the POEO Act applies in respect of notices given by an authorised officer pursuant to subsection (2) in the same way as it applies to notices given under that Act or the regulations under that Act, except that in so applying that section a reference to a regulatory authority is to be read as a reference to the Director-General.
(3B) For the avoidance of doubt, a prosecution of a person for an offence against a provision of Chapter 7 of the POEO Act (as applying under this section) is to be taken as if the offence were an offence under this Act.
(4) The functions that an authorised officer has under Chapter 7 of the POEO Act are, for the purposes of any provision of national parks legislation, taken to be functions under national parks legislation.
(5) If an authorised officer has functions in respect of a matter under both Chapter 7 of the POEO Act (as applying under this section) and under any other provision of national parks legislation, the fact that there is a restriction on the exercise of a function under national parks legislation does not of itself operate to restrict the exercise by an authorised officer of any similar or the same function under Chapter 7 of the POEO Act.
If you're wondering what a penalty unit is when you see maximum penalty units for offences in NSW Legislation, 1 penalty unit = $110
http://www.legislation.nsw.gov.au/maintop/view/inforce/act+92+1999+cd+0+N
Crimes (Sentencing Procedure) Act 1999 No 92
17 Penalty units
Unless the contrary intention appears, a reference in any Act or statutory rule to a number of penalty units (whether fractional or whole) is taken to be a reference to an amount of money equal to the amount obtained by multiplying $110 by that number of penalty units.
wavike
Unlikely to be used but -
(3) Power of arrest
PINT of Stella. mate!
Many, many Scotches
Saw this thread, got all excited but then I find out that the NPWS don't have their own Power Rangers and in fact it's just a misleading thread title.
Thanks for getting my hopes up. :rolleyes:
tc2233
I have come across some park rangers when riding on the tracks you aren't allowed to ride on. I just turn the bike around and ride off. They have never been bothered to go and chase me so far...
