NSDynamics
Farkin Advertiser
Here at NSDynamics we are having a clearance on rear shocks and springs.
These shocks are new and have never been ridden. Some may have cosmetic damage to the decals, or may have marks from being fitted to a bike but have never been
ridden.
ridden.
Fox DHX 5.0 2010
Coil Shock
241mm / 9.5” Eye to Eye
76mm / 3” Stroke
Adjustments - Rebound, Propedal, Bottom Out, Boost Valve
$350
Manitou Revox ISX 2010
Coil Shock
222mm / 8.75” Eye to Eye
68mm / 2.75” Stroke
Adjustments - Rebound, Low Speed Compression, High Speed Compression, Bottom Out, Pedal Platform.
$290
Fox DHX 3.0 2008
Coil Shock
76mm / 3” Stroke
Adjustments - Rebound, Boost Valve
$275
Manitou Revox Intrinsic 2008
Coil Shock
76mm / 3” Stroke
$260
Manitou Swinger 4 Way SPV 2008
Coil Shock
76mm / 3” Stroke
Adjustments - Rebound, Low Speed Compression, High Speed Compression, Bottom Out, Pedal Platform(SPV)
Cosmetic damage to decal, marker pen on body
$230
Manitou Split RPA 2010
Air Shock
68mm / 2.75” Stroke
Adjustments - Air Pressure, Rebound, Pedal Platfrom
Small marks on decals
$190
Fox DHX Air 5.0 2010
Air Shock
200mm / 8” Eye to Eye
57mm / 2.25” Stroke
Adjustments - Air Pressure, Rebound, Propedal, Bottom Out, Boost Valve
$350
Manitou Evolver ISX 6 2010
Air Shock
56mm / 2.25” Stroke
Adjustments - Air Pressure, Rebound, Low Speed Compression, High Speed Compression, Bottom out, Pedal Platform
$335
Manitou Swinger X6 SFS 2010
Coil Shock
56mm / 2.25” Stroke
$280
Springs
Marzocchi 450 x 3.0. $70
Marzocchi 400 x 3.0. $70
Marzocchi 300 x 3.0. $70
Fox 350 x 3.70. $70
Fox 400 x 3.25. $70
Fox 300 x 3.25. $70
Manitou 550 x 2.25. $60
We also have a range of reconditioned shocks and forks. see For Sale, Frames/Forks/Shocks.
If you don't see what you're looking for drop us a message as we may be able to help you out.
Also... T-Shirts $25!
