Ignore Josh, he is ill informed.
You are losing a little bit of the float fluid from the air sleeve there is normally around 5-7ml in there and assuming you get your bike serviced regularly (annually at least) and your bike shop are reasonably switched on the air sleeve should get done every year.
It will not effect your damping although its natural for the quality of the damping to reduce over the lifetime of the shock, a more advanced service from NSD Tekin or similar will fix it up any damping issues
The only reason it is common on autosag is because the valve is reasonably low and your letting air out quickly if you took any fox shock and held it overnight so the valve was low and then released the pressure quickly (eg allen key in the valve) it to would let a little bit of oil out
I thought I should add the reason some other brands of air shock don't do this is they use grease instead of fluid in the air chambers.
Josh,Yeah I just made that whole thing up like I am ill informed of my experience. Well just so you know this was first experienced on a new bike. So it had nothing to do with wear and tear. And the "oil" is more like snot and it is a good amount. As I said from actual experience when it comes out, I loose damping. It's not a mist of float oil spraying on my finger. It's more like my shock blew its nose on my finger. I'm not sure how the damping oil gets into the air chamber, but it has happened to me several times. It may have something to do with the fact that I'm 205lbs (my bro too) and the excessive pressure is causing a seal to blow out quickly upon Auto Saging. I do know that specy warranties the problem. But after a three shocks for me, I just stopped using the Auto Sag feature.
Guys. It's not a little spray of float oil coming out. I clearly know the difference between damping and the air spring. I also know the fluid coming out of the auto sag is not blue float oil. The first time it does it it is about a quarter of a pillow packs worth. With the brain turned all the way on I have free play before the remaining fluid stops the movement when the brain is fully closed. At which the shock does not move before the snot coming out off the auto sag. At this point the first part of the travel with the brain fully on you hear a slurp sloshy sound where there is no fluid but now also air in the damping unit. And this is not a maintence time issue. Specialized did say they have problems with bikes that have been on the floor for a year just sitting there prematurely wearing out the seal with out movement. My problem is the real deal and you can make it out like I'm lacking in knowledge and understanding of how a shock with a remote damping unit controled by an adjustable inertia valve works, but I just happen to understand. Trying to take my experience and act like I have no knowledge of what I'm talking about is like you working for Specialized claiming that the problem isn't real. FYI float oil is not yellow. The damping fluid is what color? Do you know?
yep very very quiet clunk, need to listen for it. Think its the inertia valve fully closing against the pressure? I'm a sick fuck, running mine full hard on a World CupLink, do you get a slight clunk when compressing the rear end by leaning on the bike? I'm getting this with the brain in the softest setting.
2014 Epic comp
Forks green, shocks red?Damping oil in a fox shock is red.
I do know this, I spent years of my life up to my elbows in it.
irrelevant there is no way the autosag feature can affect the damping.
The nitrogen charge transfer issue or potential shaft bushing issue you have is 100% unrelated to autosag, I'm not debating you have issues with your shock its just unrelated to autosag.
