Firstly - Bead Seat Diameter (BSD) is the only standard measurement in tyre sizing so always use this as a reference.Wow, what a hassle fitting a tyre, i had a standard road tyre and was way too small, whats the go with this? the more you know, the more confusing it gets
Pads on steel are always going to be shit in the wet. Alloy will help a bit, and also reduce some weight. Otherwise just keep them adjusted well and rub the pad surface with sandpaper every now and then to stop them glazing over and they should work sufficiently. I have an old Raleigh Lady Sports I'm doing up and you want to start braking on that thing a good 50 metres before you actually need to stop.Awsome, thanks a lot mate
Almost died thinking breaks would work in the wet like my discs 29er brakes would :distrust: Is there a type pad i need for the crap old steele wheel or i need alloy wheelset to have efficient breaking using pads in the wet? or are pads are always going to be shit in the wet?
Elbo, It is the crap early 80s bike, spewing!!
Good find, I think it looks nice!I am wanting to keep the nice old clicking freewheel noise it makes, i would really like to keep that. Is sounds more like a ball bearing type of tapping noise rather than the ratchet sound found on the newer hubs, Is this a noise limited to the older Araya Japanese wheels or is this just the how the wheels were in the old days?
The headset is Sieko and the cranks are Sugino. Replace or refurbish via the electro method?
The clicking freewheel noise is because it is a freewheel (similar to bmx freewheels for example) as opposed to a cassette type mechanism.
I recently did up an oldie, had Sugino cranks like yours, they're actually really solid (and heavy) compared to higher end or more modern ones.
Once I stripped mine I found there was rust under the paint as well and took some effort to clean up properly...namely lots of sanding! (you can buy stuff from the hardware to get rid of rust, comes in similar tins to paint stripper, but I've never tried it).
If you only have very minor surface rust you could try really fine wool (eg Sifa brand from the hardware store), I don't think brasso would do much for rust, could be wrong though.
Mine ended up like this, thanks to some parts of a nicer but still old Repco. It originally had the 27" steel rims like yours (which weren't much good), on it now are the 700c ones off the Repco. They fit fine but the brake pads only just manage to reach, sitting at the lowest spot in the caliper thingys.
One thing to watch with these old road bikes is the hub spacing if you're planning on replacing the wheels at any time...they're obviously different spacing to mtb's but they're also different to modern road bikes. Sheldon has some info about "cold setting" on his website though.
Very cool, I've bookmarked that page to have a proper read another time, it looks like a very interesting method to try out on something one day!Thank you pebble, I will restore this one to it's original if i can somehow get the rust out of the rim using the following method http://myweb.tiscali.co.uk/andyspatch/rust.htm
