Raw Toast Man
Any one had any experience with the mtbs? Im looking for a new bike and looking at this option.
I know Stu has the road version.
Might run this for a spec. Not bad for under $3k 10.23ish KG
Frame: MT
Seatpost clamp : 34.9mm seatpost clamp
Frame size : 19" $703.00
Fork: Marzocchi Corsa SL World Cup 80mm Pearl $655.71
Headset: ZS COMPATIBLE AHEADSET $25.00
Headset Spacers: Carbon headset spacers
Headset spacer height : 10 mm $3.00
Seatpost: THOMSON POST 410MM 31.6 BLK $42.75
Crankset: SHIMANO XT FC-M760 w/ INTEGRATED BB
Crank length : 175 mm $184.70
Chain: SRAM PC-991 CHAIN 9-S $23.34
Front Derailleur: SRAM X.9 F/D 34.9 HIGH CLAMP TOP PULL $24.90
Rear Derailleur: SRAM X.O. R/D MEDIUM CAGE $152.28
ATB Brake and Lever - Front: SHIMANO DEORE XT BL-M765 LEFT W/BR-M765 FT $129.05
ATB Brake and Lever - Rear: SHIMANO DEORE XT BL-M765 RT W/ BR-M765 RR $132.49
Disc Brake Rotor - Front: SHIMANO DEORE XT SM-RT75S ROTOR 160MM $12.11
Disc Brake Rotor - Rear: SHIMANO DEORE XT SM-RT75S ROTOR 160MM $12.11
V-Brake Levers:
Shifters: SRAM X.O. GRIPSHIFT $44.61
Handlebar: EASTON EC70 XC CARBON BAR $51.50
Grips: PEDROS GRIPS $2.49
Stem: EASTON EA70 ATB 31.8 STEM
Stem length : 100 mm $42.49
Tubes: MICHELIN 26X1.90/2.10 PRESTA TUBE $3.96
Front Tire: RITCH Z MAX MILLENNIUM PRO 26X1.90 $16.21
Rear Tire: RITCH Z MAX MILLENNIUM PRO 26X1.90 $16.21
Wheelset: FULCRUM RED METAL 1 $501.85
Cassette: SRAM PG990 9-S
Cassette combination : 11-12-14-16-18-21-24-28-32T $54.93
Saddle: San Marco Aspide Ti Black $103.18
Pedals: SHIMANO PD-M540 PEDALS $48.28
Frame: MT
V-Brake Levers:
