slo
Hi all!
just got new bike, going through initial set up.
Running some 130mm Pike RC with charger damper. Rear suspension is sorted.
Im more of a trail rider than enduring bro.
Looking for heavy dudes setups (psi / how many bottomless tokens you run) and how you've found it.
Sram site says if you're above 90kg, you need between 105-163psi (broad), I understand I need to set it to 20% sag. Just looking to narrow down the psi if someone of similar weight can chime in.
Regarding tokens, helped a buddy set up his forks a while back. He weights 80kg, but rides more aggressively. Threw two tokens in his, but he found that created too much resistance in final stroke, so we dropped it back to one token and he is happy.
Because I am heavier, should I go straight to two tokens... Or because I'm less aggressive should I initially try one and go from there??
Thanks for the assistance!
