mr_h._simpson
Hello,
I've had a Pivot Mach 5 for about a month. If you overlook the fact I keep crashing it I've found it to be a fantastic bike!
The problem is I keep losing the front end. It goes into understeer and washes out. The only changes I've made from stock are a 10mm shorter stem to 90mm and replacing the low rise 660mm bars with low rise 685mm bars.
I'm runing 25% sag on the fork and 30% sag on the shock as recommended by the LBS. The fork had a lot of stiction at first but has gone now it is broken in. I've set rebound on the shock as 3 clicks from full slow. The Pivot web site recommend 1 or 2 clicks from full fast but I found that way to fast.
Any suggestions on setup would be very appreciated thanks!
Bye.
Andrew
Bye.
Andrew
