petertronica
Hey Burners,
The hub is a shimano FH-M8010B 148x12 boost (XT hub).
I'm trying to track down an annoying creak. Just can't figure out where it's coming from. But then, in my investigation, I've found some play in the rear hub:
If I grab the top of the largest 46t cog (while the cassette is on), I can wiggle it back and forth at least 1mm, more like 2mm.
When I take the cassette off, turns out that the cassette is on tight, and the play is the freehub. I don't have a 15mm allan key so not sure if the freehub is screwed on to the correct torque, and having watched a quick service video, I'm not sure how game I am to take it off given there are 72 loose ball bearings inside.
I don't know if there's supposed to be a bit of give, of if something inside is loose? Anyone know?
If it's loose, I'm wondering if this could be the source of the creak...
Thanks in advance!
Thanks in advance!
