please delete
try loosening bolts on brakes press the lever in and hold and tighten the bolts back up (use a rubber band on brake lever works) should realign caliper to rotor and issue solved... Happens a lot as well may not be back in exact same spot... if not fixed make sure whell is actually in correctly ....
You probably bumped the leaver or just have it misaligned when you put the wheel in.
If you bumped the leaver and pushed the pads in too far you will have to pull the pads out and push the pistons in to reset them (I use an appropriately sized spanner ring end or sometimes a tyre leaver will be ok).
If it is just misaligned look down the top of the caliper and try to align it by eye so there is even space either side. You can also do the loosen the caliper bolts, hold the brake then re-tighten them, I find using my eyes works better than pushing in the brakes.
hope this helps
