EDIT: It is. See latter post in this thread for discussion and pics:
https://r.tapatalk.com/shareLink?ur...share_fid=1708&share_type=t&share_pid=3106942
Is there anybody who is running – or thinks it would be possible to run – a right hand Reverb lever under the bars on the left hand side, on the outside of Shimano XT M8000 brake and shift levers? Better yet, have you got a photo of the setup?
I'm about to buy a new Trek Fuel EX, and I'm trying to anticipate if I will be able to get the cockpit 'just so'. Having demoed a Fuel EX 9 and a Remedy 9 RSL I've realised I'm very particular about the setup of my cockpit. I'm deciding between the Fuel EX 8, 9 and maybe 9.8, and want to factor in the cost of any changes I'd have to make to the stock setups before deciding which one to buy.
I've done some googling and can't find any pics of current XT levers and a Reverb lever as I describe. The most promising pic I can find is in this article on Fabien Barel's Strive setup. He runs 1x SRAM Eagle, with a RH Reverb lever under the left bar. But more interestingly to me on the right side he has a shock lockout lever –which looks suspiciously like a Reverb lever – mounted just to the outside of to a combined shifter and brake mount. I pretty sure a mirror of this general configuration on the left side of the bars would be my ideal setup.
In terms of the specifics of each of the bikes I'm considering…
The 8 comes with a KS dropper with a dinky little lever that feels horrible (at least as it's setup in the shop – I haven't ridden it), XT shifters (with current skinny mount) and Deore brakes on a separate, wide mount. If I buy this bike I'll probably replace the dropper with the year-old Reverb I have on my current bike. But the side mount of the Deore brakes makes me think it's highly unlikely I'll be able to get all the levers roughly where I want them.
The 9 has a 1x SRAM X1 setup. It comes with a LH Reverb lever above the bars, which I'd probably swap for the RH lever on my current bike, and stick it underneath. Obviously a 1x setup would be the simplest solution, but I'm pretty sure a 32-42 gear won't be low enough for my 44yo legs on big days at Buller, so I'm leaning towards a Shimano 2x setup. (If I was buying in two year's time, when 1x 10-50 setups won't be so prohibitively expensive, then this is what I'd likely go with).
The 9.8 has a 2x XT setup, on a combined skinny mount, and also has an LH Reverb lever above the bars. (It's a carbon frame, and stealth matte black, so it's the one I want to own, but not necessarily the one I want to pay for!) In the shop the Reverb lever is mounted way inboard of the combined brake and shift mount (the reservoir of the brakes limits how close it can be if mounted inboard). That's not going to work for me and my small hands.I'm pretty certain that I could mount the Reverb lever to the outside of the combined XT levers (still above the bars). But I use a dropper a lot, and I'm convinced I'd much prefer the lever underneath (I couldn't make it work with the bulky Deore levers on my 2008 Trance).
Basically I have small hands and I really want my brakes setup for one finger braking and a dropper lever resting under my thumb. I think I'm prepared to sacrifice the ergonomics of the left shifter if it's not ridiculously inboard of the dropper, if that will allow me to make it happen.
Anyone think this could work? Got any other suggestions?
