So I've had a praxis works conversion BB on my bike for a while now and have had no need to touch it. Recently I was riding along and noticed some play in the BB. For those familiar with the praxis BB, the drive dude cup had started to loosen from the NDS sleeve and was moving around slightly.
I pulled the BB or and had a look, threads send fine and bearings are still perfect. Put it back on the bike exactly as per instructions. Going to fit the crankset and there is a massive gap on the drive side. So much so that the wavy washer is just floating around on the crank spindle and the bearing cover falls off. No matter what I do when putting the spindle into the bearings, I can't get it any further. The NDS crank arm is tightened to spec and sitting hard up against the bearing.
Any ideas? I can see there is a very small lip on the NDS up to the bearing seat, I'm wondering whether I've installed the BB incorrectly and the bearings are not lined up perfectly. Apart from that I'm stumped! Am i missing a spacer?? Or something else?
