Check that base idle is right then see where the timing is, TPS is in the right range at idle?
Not clear what youre saying. Base idle do you mean the target idle? Its an electric throttle body, so no TPS - according the laptop the ecu is seeing the throttle pedal as closed and is modulating the butterfly trying to hold the idle speed.Check that base idle is right then see where the timing is, TPS is in the right range at idle?
yep, done that. except for the bottom on the lower manifold gasket due to access. The engine was sitting outside wrapped in plastic for several months - ive never heard of pressed steel gaskets failing from rust and sitting around, but willing to be educated....Start engine, spray throttle body cleaner or similar everywhere, if revs increase you have a leak there.
Classic air leak symptom. Throttle body closes and air leak causes the lean out and resultant flair.Oh yes - it flares rev/hangs when changing gears....
There should be a certain gap at the throttle body, and there will be a certain percentage of the throttle butterfly in a closed or home position where the computer recognises the car is at idle. If it's a fly-by-wire probably all fixed but I don't have any access to specs for these things.Not clear what youre saying. Base idle do you mean the target idle? Its an electric throttle body, so no TPS - according the laptop the ecu is seeing the throttle pedal as closed and is modulating the butterfly trying to hold the idle speed.
10-20secs is probably too short for what I'm about to describe, but hear me out, it might be a clue.Oh yeah - it idles ok from dead cold for about 10-20 seconds before it starts to hunt. A higher idle obviously, but made me chase fuel and O2 sensors for a while - closed and open loop differences…
Yeah, you’d think so… I couldn’t tell which of those parameters was following which.With such an erratic idle you might not pick up cleaner being ingested try wd40 and just look for a period of smoother idle. Looking at the charts again the manifold pressure is driving the other inputs though it could be injection. If it worked fine before and you didn't pull the manifold look for misplaced or kinked vacuum lines. It has to be simple if it was ok in the other car.
There is no EGR.EGR valve gasket?
Yes, does have VVT on the inlet cam - it’s an all or nothing type and yes I’ve checked and swapped the solenoid. It’s off at idle and isn’t activated until close to 2000rpm. I even hot wired that to activate it at idle and it made it all a whole lot worse, so VVT is behaving as it should.If no egr, is there variable timing on the cams? I think the only way to drop the egr is to retard exhaust cam timing (when cold) so the intake stroke can pull exhaust gasses back in.
are all valves ok? Performed a leak down test?
That’s a good trick. Tricky to hook up, there are no vacuum lines and the MAP sensor plugs directly into the manifold…Put a vacuum pump on the Map sensor and see if you can trick the computer, efi cars usually idle around 20 inches of mercury, if the idles smooths out you'll know what the problems are.
Maybe… but MAP and air temp sensor plug directly into the plastic upper manifold, there is a brake booster feed and inlet for vapour canister purge on the throttle body. That’s it. Throttle body has a duct to the air filter, which has nothing on it itself.Do you have a sketch of the intake system and connections?
