Heya guys,
You can corner weight a car by shimming up the stock struts between the chassis and top plate.
Easy to do and well within the rules as most older cars did this from the factory to help rectify out of tolerance bodies as they came off the line.
It will take a little longer than spannering some coilovers, but for a more balanced car, it must be done.
The best suspension in the world is useless if your car is corner weighted like a busted ass shopping trolley!!
Make sure you scale it in race trim. Half tank of juice, driver in position, correct tyre pressures etc etc
It’ll cost you a few hours, a case of beer and some pizzas when your mates drop over (I assume you can borrow some scales from someone).
I haven’t kept up with this build/thread. But some chassis strengthening is needed to use the corner scaled setup to it’s potential. Otherwise everything will move under load anyways.
Even some basic stitch welding will help if you haven’t got a weld-in cage (bolt-in does nothing for chassis rigidity)
On a side note, I’m looking to sell my RX3 and go tarmac rallying in the near future
Should be fun!!
Mark
