Tape is chewed through pretty quick on any trailer I've used than has the slip in crank design. Don't think OP is worried about the force, so much as the gouges and damage to the crank arm. I haven't seen a perfect solution yet, sorry.Depends on the trailer and how well the bikes are tied down or not, thrown into the back of an 8x5 might not be so good but a purpose built shuttle trailer should be fine. I think the carbon will be strong enough to handle shuttling, think of the forces you put through your cranks, it's strong stuff. If you're worried about marks a few layers of leccy tape will protect them from scratches.
Harsh design. Cut strip of folio cover to outside then, could make it look like just tape but have the extra protection.Tape is chewed through pretty quick on any trailer I've used than has the slip in crank design. Don't think OP is worried about the force, so much as the gouges and damage to the crank arm. I haven't seen a perfect solution yet, sorry.
They still get mangled but....Solution is to buy an alloy crank.
Sent from my SM-N910G using Tapatalk
I can say with 99% certainty the FSA won't fit. Even if you are usually 24mm spindle, the gxp step down to 22 for the splines...even if splines were similar.Great thanks guys...I am going to try installing my cheaper FSA gossamer (from my crossbike) tonight to see if I fits.
Might feel a bit weird with it being 2.5mm shorter than my current crank. Hopefully it will fit otherwise I will buy a SRAM GX1000 to replace it.
That has mega thread potential written all over it....Take pedal off.
Slip inner tube over crank
