Cardy George
Don't forget the bouncing and shaking and the leveridge the bike rack would have. The ladder may take your weight, but is that only when the van is stationary?
Hang on champ! It'll be bringing those wheels up you might want...Oh shit, it's french. Parts will fall off by themselves, let alone with something else bolted on
What?!! How can I van surf if I'm climbing it stationary??Don't forget the bouncing and shaking and the leveridge the bike rack would have. The ladder may take your weight, but is that only when the van is stationary?
Are you riding Tewantin that weekend?Oh shit, it's french. Parts will fall off by themselves, let alone with something else bolted on
Unless I can't shake this cold, or hell freezes over.Are you riding Tewantin that weekend?
Yeah, that too... Well, one way to find out. If you one day look in the mirror and see your bikes skidding along the road with a door attached to them you'll know the answerDon't forget the bouncing and shaking and the leveridge the bike rack would have. The ladder may take your weight, but is that only when the van is stationary?
I'll black out the rear doors. Outta mind outta sight.Yeah, that too... Well, one way to find out. If you one day look in the mirror and see your bikes skidding along the road with a door attached to them you'll know the answer
Yep. Probably right. I know these are bigger vans but they mount on a single door so for the odd trip it should be ok. My worry is more to do with the load being centred over a much smaller area using the 4X4 buzzrack. Unlike the ones that use rails that spread the load widerI would guess if anything it will prematurely wear the hinges out early in life, the rear doors hinges would need to be designed strong enough to be able to take a decent impact up the bum.
You have the option of welding or bolting larger foot plates on or using long steel flatbar brackets to your existing rack and then sandwich plate it through the door skin, you'll want to use some type of rubber in between the clamping because otherwise it distorts the doorskin on the outside and looks horrible, that's why they usually use those 'revit nuts' on the old hilux winged door mirrors that have a small protrusion of the nut on the outside of the doorskin then have a rubber seal between the door skin and mirror mount, besides the rubber seals the inside of the door from water getting in.Yep. Probably right. I know these are bigger vans but they mount on a single door so for the odd trip it should be ok. My worry is more to do with the load being centred over a much smaller area using the 4X4 buzzrack. Unlike the ones that use rails that spread the load wider
That's a good idea. I hadn't thought of bolting a foot plate to it.You have the option of welding or bolting larger foot plates on or using long steel flatbar brackets to your existing rack and then sandwich plate it through the door skin, you'll want to use some type of rubber in between the clamping because otherwise it distorts the doorskin on the outside and looks horrible, that's why they usually use those 'revit nuts' on the old hilux winged door mirrors that have a small protrusion of the nut on the outside of the doorskin then have a rubber seal between the door skin and mirror mount, besides the rubber water proofing the inside of the door.
