Sold Rear 29" Sun Ringle Charger Expert, Front 29" XT M8020 (Non-Boost)
Isaakk
Item: 29" Sun Ringle Charger Expert Rear Wheel, non-boost, 135-QR and 142x12mm end caps, 6bolt
Item Condition: Used, but good condition. Straight/true, perhaps 1mm max deflection.
Reason for selling: Replaced with Hunt wheelset.
Price and price conditions: SOLD
Extra Info:
Taped for tubeless with valve installed. Includes both Shimano (some marking from cassette) & XD drivers. Charger and SunRingle decals removed.
Item: 29" XT M8020 Front Wheel, non-boost, 100x15mm, Centrelock (can include 6bolt adapter)
Item Condition: Used, but good condition. Straight/true.
Extra Info:
Pictures: Temporary, will grab proper ones later.
364310
142x12mm end caps
What do you mean by this?
Really sorry. I'm new to mtb
Sent from my SM-G965F using Tapatalk
No worries - The rear wheel is either 135 QR (your standard quick release), or 142x12mm thru-axle. You can change between either of the options by changing out the endcaps, which slot over the end of the axle on either side. Basically, you can run the rear wheel as either option by swapping between them. The front wheel is 100x15mm thru-axle. :)
OK
Well my rear wheel is qr as you explained. Cheers
I'll check my front wheel tomorrow arvo.
I'm keen.
Is there any lateral bearing play in either?
OK
I'm keen.
Nope, not that I had ever noticed. Will double check this afternoon though just to make sure.
