Wilson_753
Hi Guys,
I'm nearing the end of a build however am having a hard time installing the rear derailleur and getting it functioning properly. I have set the limits, but it doesn't seem to be sitting in the frame right, it looks too high and is rubbing on the frame when in the highest gear (small cog). The derailleur is pushed up against the tab on the dropout but it still looks odd. I'm thinking the chain is too tight, however I followed Sheldon Browns chain length guide to the T, eg. big-big with one full link extra, http://sheldonbrown.com/derailer-adjustment.html#chain. It's on a hard tail, how do others measure there chain?
Also another problem, I'm running 1x10 from a 2x10 XT crankset with the ring in the outer position, I heard there may be problems with chain line but mine is terrible, front ring is centered near the lower end of the cassette maybe gear 7-8. When in the lowest gear (big cog) there is bumping and other none smooth noises going on, I have a 73mm BB with the standard 2.5mm spacer on the drive side. I could take this out however my chainring is very close to the frame as it is, any other solutions?
I've attached photos below, all solutions will be useful, Cheers.
