Beej1
Senior Member
Hi All,
I am interested in getting a Giant Trance (either buying the 1 and swapping parts, or hopefully finding a decent frame), and have a question about it's rear suspension.
Giant lists it as having 4.2in of travel, and it has either a Fox Float R, RP2 or RP23 Shock depending on model (2, 1 or 0 respectively). I was wondering what determines the 4.2in of travel? Is it the physical limitation of the frame itself, or is it the shock? or is it a combination?
I realise that the physical limitation of the frame has to come into effect - it can't have endless travel. But I was wondering if perhaps a longer travel shock is able to be inserted, maybe pushing it up to 5in or slightly more travel by extending the swingarm out by 0.8 of an inch or more? The Fox website seems to list each of the 3 aforementioned shock's as being available in a number of lengths.
And I guess while I'm at it, if this IS possible, could you do the same thing to a Specialized Epic with it's whole Brain thing going on? I'm keen on an Epic Marathon frame in this forum, but wondered if you could push it from 100mm out to 130mm travel?
Thanks in advance for any info. I've been lurking around here trying to find an answer to this for a week or so but my searching is known to be not-so-great in the past.
