BS, they were sold out last night! Cheers
Sounds promising :faint:(number cancer found in my sale threads)
All,
Having a torrid time trying to track down some Rock Shox 30W oil for a lowers service.
Tried LBS, motorbike stores and online for a fork oil...
Any ideas, or even better someone with 30mL to spare in Geelong/Werribee/Hoppers?
Cheers
I serviced my pikes about a month ago after about 20hrs, I couldn't find the rs 0w30 fluid so found some synthetic moto fork oil of a bit lighter viscosity (Lucas 15w). Did the same thing added 10-15 ml to each of the lowers and used slick honey on the air piston with about 5ml of oil on top. The difference in feel from new was very noticeable, supple, smooth and more responsive.Can I recommend to scrap the standard RS oil for your lower/ seal service, and use the Fox 20wt gold. The makeup of the RS Pike oil is quite heavy (without getting tech), and gives your fork quite a harsh feel.
12mL - 15mL each leg will change the way your fork rides, also rebuild your air spring with Slick Honey, and Float Fluid, instead of the grease as recommended.
Good Luck,
Brad
Thankyou tekin!!!!! Thought I was imagining how crap my forks felt after doing and oil change with the rockshox 0w30w. With the float oil and slick grease am I just wiping that round the seals? Thanks for the tip !Can I recommend to scrap the standard RS oil for your lower/ seal service, and use the Fox 20wt gold. The makeup of the RS Pike oil is quite heavy (without getting tech), and gives your fork quite a harsh feel.
Good Luck,
Brad
Thanks again mate, just waiting on the Fox 20wt and slick honey to arrive then its on. Can't wait to get that lovely bottomless pike feeling back again! Just out of interest why is the recommended rockshox oil so shit when that's the original stuff that's in there to begin with? The fork just felt awful after I'd done the oil change, I've been running lower pressure to try get it to feel right but I was just blowing through all the travel.Never use float fluid on your foam wiper seal - the viscosity of the oil is to thick, and tends to do more damage than good as it cannot lubricate the stanchions enough. Soak the foam wipers on the lower leg oil (in this case Fox 20wt Gold). Rebuild air piston with a lining of slick honey, and 3-5ml of fox float fluid, apply slick honey to your lower bushings, install lowers.
You'll never know your fork after that.
I replaced all fluids in my new ones after a few rides with:I'm running 2014 SIDs, what is the best oil to use?
Any other set up tips?
1 is 100mm XX, the other 120 RCT3
cheers
