Rockshox Revelation Increasing Travel to 150mm. How does one do it?
stinkytodamax
Hi Guys
Calling on the brains trust. I'm looking at a Revelation RL with Dual Position 120-140mm on a 2015 Giant.
Can these forks be extended to 150mm or am I lumbered with selling them for a longer travel fork?
Any advice would be apprieciated
Cheers
JP
Hi Guys
Cheers
JP
Dual air or solo air? Solo is harder, dual is a via spacers usually.
edit. Missed that it's on a 2015 giant. I don't think you can. I'd see if you can swap someone.
99_FGT
Longer air shaft? You can go down, pretty sure the uppers are the same for all travels on the revs and pikes, so changing out the air shaft should increase it.
Al..
Al..
May be right. Not positive of these. Revs have been 140 for the last couple of years, haven't they? Might not be compatible with parts on 150mm sets. I could only get 140 when buying new revs last year.
teK--
32s would also get quite noodly once u pass 140mm travel unless u are a really light rider.
mitchy_
Llama calmer
My 2015 revs were 150mm.
Dual position aren't easily converted though, only single pos with a new air shaft.
As far as I know, Rockshox have dropped dual air all together? So not just a spacer job like older revs.
Yeah, no dual air since 2012, I think :doh:
To be fair, was only looking for straight steerer revs last year, so the choice may have been limited.
Fox, sure. Never found this in my 150 revs. Ran them on the spitty for a while and pushed them pretty hard. That said, my huskier mates felt s bit more flex.
stinkytodamax
Good to know the Rev's are reasonably stiff then. I'm about 90kgs with all my gear. I have a set of 32's on my XC bike which don't enjoying getting too wound up on downhill runs.
Thanks for the help so far.
JP
mitchy_
Llama calmer
The ones on my commy were 150mm straight steerer.
JP
As someone who is ~90kg (last time I weighed myself anyway, I think my soon-to-be-wife is starving me though...) and had 140 fox 32's, 140 revs and 150 pikes on the same frame; revs definitely feel firmer than the foxes. That said, the pike makes both of them feel like a floppy penis.
stinkytodamax
Point taken. The plan is to save for some Pikes or x fusion Sweeps (reviews seem good) and a longer stroke shock but in the short term I'll need to use the Revs.
Listen to nigs. If anyone knows the feel of a floppy penis, it's him. :nod:
waldog
In they're the same spring setup as a dual position air lyrik, then you're plum out of luck and floppy cocks.
Dual pos have a dimple on the inside of the air spring stanchion that regulates the pos and neg spring. It's only compatible with dual pos. If you're desperate to do the conversion you have to buy a new CSU.
Leave them at 140, enjoy them in semi chubby form and get some sweeps.
You're welcome.
schred
A current rev 140 compared to the fox float 32 140 is night and day difference, not all 32mm are created equal. Havent had a go on a pike, but have a set of mattocs and in 150 are better again.
