Sold Rockshox Reverb A2 Stealth 125mm 30.9
rangersac
Medically diagnosed OMS
Item: Rockshock Reverb A2 Stealth 125mm drop; 30.9mm seatpost, 420mm length, standard remote.
Item Condition: Good, works as SRAM intended.
Reason for selling: 170mm Oneup
Price and price conditions: $125
Extra Info: This dropper came on gbear's Spitty that I picked up so I cannot swear by the exact usage it has received. However, since I've owned it it's only had about half a dozen rides as my Primer takes care of most of the regular trail duties. There's virtually no play in the post and it has always worked without issue for me. The connection is the hose barb with barb sleeve type, so it will need bleeding after installing. Where the top of the stanchion meets with the seat clamp there's minor wear of the anodising on the seat clamp (probably from an arse saver mudguard), and there's one tiny (and I mean tiny, the size of a pinhead) mark on the stanchion that doesn't affect performance. You can just see the mark next to the bright reflective patch in the photo. The bike is a large size so the hose should fit pretty much any bike unless you are XXL giant.
Pictures: Yep, feel free to request more.
