Roid Rage
I have 2014 Sid which became stuck down recently.
Supposed to be a 100mm fork, I was lucky to see 70mm. I dont think I even noticed for a few weeks.
As previously suggested in this thread it ended up being a -ve air pressure issue. Air had moved from the +ve side to the -ve.
Solution ended up being removal of the rebound knob and sending something long and skinny in the hole to release a very hidden away valve, quick hiss and problem solved.
Since there seems to be a few Sid users in this thread I am curious about peoples thoughts on the recommended air pressure for the Sid. I have been running the fork at 80psi (I have never checked the pressure until tonight after owning the bike/fork for 2 months), the chart on the fork recommends 120-130psi for my weight. I pumped the fork up accordingly and I am not confident I will see 100mm of travel unless I send it like Bender.
