Thanks to Kegs for getting this thread started if for anything, its entertainment value.
And thanks for the props Matt I appreciate it and as for our efforts to produce a working proto, yes it is an ugly duckling but then again its a proto
and its a Lawwill and...well you get my meaning.
And as all can see, it was never meant to be accepted by the general public as a sexy production piece. It cost money to produce sexy you know...
As for the machining on the backside of the cranks that was done by Nicolai for clearance from the gearbox itself and were included with the gearbox.
This proto was meant to have Karls 7 speed (NON-ROHLOFF) gearbox. These were not ready in time for Interbike 06 and because of this it was a mad scramble to make the inital design work with the 14 speed.
As for riding it, it works, it feels as nice and it does want it was designed it do and for being done in such short order I'am pleased. As far as i'am concerned it proves a point......that you can build a floating shock, Lawwill 4 bar link as a gearbox!
Our next samples will be more refined but then again Rotec won't build a production gear box bike for at least 3 more years and even then it'll be a very limited run. Hell I'am stoked it even got made for the show and for that reason it was a success, heck their were only maybe 3 or 4 total in vegas and Rotec was the only one you could ride and pedal around!
Designs like this are meant to inspire thought and create feedback which btw is very important for a small builder like myself to get from the gereral riding public.
Thanks for the forum Kegs!
Great to here from you Sully.
Thanks for clearing up the crank thing, this was my major concern (apart from a little untidyness, but hey, like you said, you already know that).
So it is a rearward axle path right?
How does it ride compared to a conventional Lawill? Small bump sensitivity better??
You have inspired me to possibly play with my DH9 and a Nexus 8 speed I have lying around home.
I started playing around modelling it up and chucking into linkage last night with interesting results.
One thing, where your gearbox is placed, it must be close to zero chain growth anyway right?
Again thanks, big props to manufacturers who get onto forums and actually respond.
It's interesting that they've gone for the rearward axle path. Wasn't the original Lawwill designed to be as vertical as possible?
I believe you are right, but a vertical wheelpath from what I can understand is a compramise between rearward and chaingrowth, something you don't need to consider when the gearbox is higher. (Look at balfa/canfields rollers and hondas output compared to their rearward axle path)
