Nickel isn't single pivot. $700 should but you a mint s/h frame if you look around.Never tried a single pivot any good ,def simple + better than a hardtail ?
There is a Pivot Mach 4 medium on ebay USA.
I found a great small Santa Cruz 5010 frame $1200 but they wont repack it or send out of USA so I need a 3rd party sender .
Well, kinda. Rear swingarm is single pivot, but there's an extra linkage up at the shock.Whatcha talkin' 'bout, Moorey? It's as single as a pivot can get!
I'll give you that....but I'll call BS on 'as single pivot as single pivot can be'.Single pivot references the axle to main frame connection, not the shock actuation.
You mean the Nickel is a single pivot with a linkage-actuated shock.
It's a single pivot ;-)
