looking at getting this
http://www.bikes.com.au/p/370641/2008-scott-genius-mc-30.html
or the mc 40
who has one and what do you think ? is the Sram any good ??? or stick to shimano... ???
Yes! I have an MC30, although mine is the carbon frame, perhaps they changed it this year?? I've had mine 12 months. Sounds like the same spec everything else?
Basically, its a pretty nice bike, BUT it took a while to make it a nice bike......
firstly, it comes with a quick release seat clamp?? It seems Scott are doing this with a lot of there bikes. Mine wouldnt stop slipping until I got a proper one. And cause its a 36.8 pole, there arn't many after market options.
I also had a heap of problems with the rear shock. It would allways leak air, causing it to bottom out badly all the time. I would allways be hitting cranks and pedals etc. (it also seems to have a pretty low bottom bracket height?) It went back twice in 6 months. Basically dont take any notice of the pressures the manual says, set it up by measuring sag....
As for the Sram......well I guess thats also a personal opinion, but it was my first bike with Sram, and I have just built up a new hardtail with Shimano, so I guess there is your answer? I dont really like the shifters, but thats a personal choice, but the rear mech has worn a lot? The pivots have a huge amount of slop in them, and did so quite quickly, so when you shift gears, it has to take up a lot of the slop before shifting cogs? As for the cranks, well they lasted even less time? Well, I guess maybe not the cranks, but the bottom bracket. It was really sloppy after about 3 months, less than 1000km. But you cannot put any other bottom bracket in it, only a truvativ will fit due to the taper in the cranks. I bought a LX crankset and have had no troubles, and have had an XT groupset on another bike with outboard bearings that are over 2 years old with no problems at all.
Oh, the brakes are AWESOME. Have never had to touch them, cant even say I have cleaned the pads or anything, very happy with them.
The forks are great too.
I'm no sure what purpose you are buying the bike for, but its a great allround bike. I have raced it a few times, but its a bit of a handful in the tight stuff, it seems really long, plus with big wide bars....but I guess its not a race bike is it? Hope this helps?
