THanks. The fork has 32mm stanchions, for 27.5" wheel, Evo, and has 140mm travel. I'll check that thread though.you haven't mentioned many of the specifics about your fork (i.e. 32/34/36, 26/27.5/29, travel), but this question was covered in this mtbr thread:
http://forums.mtbr.com/shocks-suspension/2014-fox-fork-oil-volumes-893995.html
which implied that (lower) 2013 oil volumes are ok (for open bath damper).
oil volumes found here: http://service.foxracingshox.com/consumers/Content/Service/oil_volumes.htm
Not gonna hold your hand but www.ridefox.com.THanks. The fork has 32mm stanchions, for 27.5" wheel, Evo, and has 140mm travel. I'll check that thread though.
Why don't Fox publish a similar page for 2014 forks?
It's this kind of policy with Fox that makes it a pain for the end user who is willing to learn and has some technical ability.Not gonna hold your hand but www.ridefox.com.
I also think that the expectation is if your are self servicing you will understand enough about suspension and the product range to work out oil volumes quite simply.
Yeh mate, I don't see any info on there re oil volumes for 2014 forks. I've serviced my forks in the past by myself.Not gonna hold your hand but www.ridefox.com.
Thanks for sharing.I have the same fork and sent Fox an email, the response was:
"Hello,
This fork will require 30ml of FOX green 10wt. in each leg.
Thanks,
FOX
831.768.4801
915 Disc Dr., Scotts Valley, CA 95066"
I agree, it sucks that they don't put the oil volumes on their website anymore.
If you do, test that you get full travel. If the 30ml is not causing some sort of hydro-lock then its all good.I'm compelled to use 30ml in both legs when I do next service.
Cheers for the tip I now recall overhearing some time ago at the LBS that they would use less than the Fox recommended amount for this reason. So much so when I serviced my mate's forks (2012) he insisted I only use 20ml in each leg rather than the full 30.If you do, test that you get full travel. If the 30ml is not causing some sort of hydro-lock then its all good.
Note: Reducing air volume in the lowers can increase pressures on bottom out that can cause the seals to pop. If you get this occurring then you will need to reduce the volume of oil in the affected leg.
This is no longer a concern with Talas 5, previous Talas generations used the stanchion as an integral part of the assembly, the Talas 5 is now an independent cart and takes up about the same amount of space as the damper. hence the increase of lubrication.If you do, test that you get full travel. If the 30ml is not causing some sort of hydro-lock then its all good.
They spec green still for 2014 because the fork will not be fitted with the latest generation gold oil wipers, gold oil is THE BOMB but if you don't have gold oil compatible wipers they wont keep the oil inside the fork, obviously you can just get 2015 32 wipers that are gold oil compatible and fit them (make sure they have it printed on the label)
http://service.foxracingshox.com/consumers/Content/Service/QuickTech/SKFsealtoolsInstall.htmHey merc-blue is there any way to tell the difference between the old vs new generation 32mm wipers by looking at them? I've got a set of '14 Talas Performance on a Trance Advanced and the LBS assured me they would have the new gold oil-compatible wipers already installed. I was planning on using the new gold oil for the next lowers service, but if the existing wipers are still in good nick I'll reuse them so would need to use the old green oil.
Also has anyone come across any how-to service guides / vids for '14 Talas forks? I understand the new Talas 5 is a much simpler cartridge-style unit which is not meant to be end-user serviceable, but I'm unsure about how to go about changing the float fluid in the air chamber.
Cheers
