scuba05
Gday guys,
I bought a DGTEC HD320PVR round xmas 08, and have started to have some problems with it. All of the VHF channels(7,9,10,1 etc) are jumping to the point that you cannot watch it. Meanwhile SBS & ABC are fine. I have tested the STB on 3 other TV's, each with different connections to the aerial, with the same results.
I ahve also tried multiple times turning it off/disconnect from power, and reconnecting, to no avail.
The STB has a serial i/p which i can upgrade the software with, but currently dont have a cable to connect it to the computer. Is it worth my while going out and buying the cable to upgrade the software? Or is it a complete waste of time, and should just buy a new STB.
Any other tests i should do to see if it begins to work??
May be unrelated, but a few of the segments for the front display are visibly dimmer than the others. This a related problem?
Thanks in advance
Thanks in advance
